ESP8266-ESP12 Eagle Part
A project log for Share the Warmth
Warm-air distribution system (PIC/JALv2)
sbigaijinsbi.gaijin 05/14/2015 at 00:390 Comments
Just added in an Eagle library file for the ESP-12 with the infamous GPIO04 and GPIO05 pin-swap problem corrected. I don't have an actual, physical PCB with this part mounted on it yet, so double check the library if you order any boards before I do (I'm a little bit worried that the pad lands may not be wide enough for easy, manual soldering). Updates welcome!
