3D Printed air-mattress plug.
Lost the plug to keep your mattress inflated? Sleep well after printing this one!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Made an air mattress plug this week.Years ago we lost the plug to our air mattress. My wife says to me "why don't you print a new one?" And so I have.Took a few tries to get the thread right for the one way valve (24mm outer diameter, 30° pitch on the thread at 13 turns per inch). I then copied that thread model, reduced the diameter it for the inside thread and then reduced it some more for the plug.Added a rubber flapper and some O-rings.Inflated the mattress and now we wait and see if it holds air...This thing was made with Tinkercad. Edit it online https://www.tinkercad.com/things/4JBuUCyGZA1Remixed from a threaded rod from http://www.thingiverse.com/thing:193647https://www.thingiverse.com/thing:921616
