One of my goals for this project is to have everything use IPv6. With many different IoT devices in each home, It does not make sense to try to cram everything into IPv4 addresses. Each home should get a /64 address space and that leaves room for a *LOT* of addresses.
The URL for PyHouse code is: http://github.com/DBrianKimmel/PyHouse
The code and fritzing diagrams for the Arduino projects is: http://github.com/DBrianKimmel/PyHouse_Arduino
