Stepper Brace Geared.SLDPRTWhere the stepper goes mountedsldprt - 274.82 kB - 02/16/2018 at 04:08 |
RodaTapaRoscaEngranaje.SLDPRTWhere the 608 bearing goessldprt - 8.72 MB - 02/16/2018 at 04:08 |
Acople a Impresora.SLDPRTMount for attaching everything to the printer carriage. Made for FlyingBear 905, but feel free to make your own mount for your printer.sldprt - 2.99 MB - 02/16/2018 at 04:07 |
EnsamblajeFoodStruder.SLDASMAssembly of how it goes togethersldasm - 2.17 MB - 02/16/2018 at 04:07 |
Gear Outer 2.sldprtBig gear, modified from +LAB modelsldprt - 1.01 MB - 02/16/2018 at 04:06 |
Gear Small 2.sldprtSmall gear. Taken from +LAB.sldprt - 519.05 kB - 02/16/2018 at 04:06 |
Jeringa Externo.SLDPRTSyringe bodysldprt - 75.16 kB - 02/16/2018 at 04:06 |
Tuerca Imprimible.SLDPRTA printable nut you can use for the threaded rodsldprt - 249.15 kB - 02/16/2018 at 04:06 |
Jeringa Interno.SLDPRTSyringe plungersldprt - 110.15 kB - 02/16/2018 at 04:06 |
Tuerca Bronce.SLDPRTBronze nut used for the pusher (came with the rod and I thought it was better to use that one than print another one)sldprt - 73.83 kB - 02/16/2018 at 04:06 |
sldprt - 85.85 kB - 02/16/2018 at 04:06 |
