LightningBlue Bean?
A project log for StormSafe
A personal lightning strike detector and dangerous weather alerting device
brian bloombrian bloom 05/01/2015 at 01:230 Comments
I've prototyped using Fritzing how The LightBlueBean should connect to the AS3935. If the Bean can't supply sufficient current from VCC, I'll add a LiPo battery to the mix with a regulator to power both devices.
