Usage Commands Found!
A project log for Reverse Engineering Toshiba Flashair Wifi SD card
My ventures in reverse engineering Flashair Wifi SD Card.
chris-jonesChris Jones 05/01/2015 at 21:241 Comment
After digging through the data and extracting what I can from the firmware update file I found the following usage data.. It still needs to be cleaned up, but it does help to identify data on the device.
Usage commands found in no particular order.. (needs to be cleaned up
usage: fat mkfs drive#
fat cat  [file]
  file : display file
fat mkfs [drive]
  drive : drive  no.(0 or 1)
       0: User, 1: System(Hidden)
fat mkdir [dir]
  dir : create directory name
fat write [file] [size]
  file : write check file
  size : write size(1-65535)
fat read  [file]
  file : read check file
fat mv  [org] [new]
  org  : original file
  new  : new file
fat rm  [remove]
  remove : remove file
fat cp  [org] [new]
  org  : source file
  new  : destination file
fat lsr  <dir>
  dir    : directory
fat ls  <dir>
  dir    : directory
usage: test read <file name>
usage: test write <file name> <file size>
usage: test cp <existing file name> <new file name>
usage: test rm <file name>
usage: test mv <source file name> <target file name>
usage: test mkdir <directory name>
srom conf  -f [flow]  -d [val] -s [samp]
  flow   : 0/1 (Invalid / Valid)
  val    : 1-10,16/32/64/128/255
  samp   : 0-63
srom read [addr] -l <length>
  addr   (hex) : 0xXXXXXXXX
  length (dec) : default 4, Max 512  (round 4byte)
srom write [addr] [data] -l <length>
  data   (hex) : 0xYYYYYYYY
Usage: ping [-t] [-a] [-n count] [-l size] [-f] [-i TTL] [-v TOS]
            [-r count] [-s count] [[-j host-list] | [-k host-list]]
            [-w timeout] target_name
Options:
    -t             Ping the specified host until stopped.
                   To see statistics and continue - type Control-Break;
                   To stop - type Control-C.
    -a             Resolve addresses to hostnames.
    -n count       Number of echo requests to send.
    -l size        Send buffer size.
    -f             Set Don't Fragment flag in packet.
    -i TTL         Time To Live.
    -v TOS         Type Of Service.(AC_BE=0x00,AC_BK=0x20,AC_VI=0xA0,AC_VO=0xE0)
    -r count       Record route for count hops.
    -s count       Timestamp for count hops.
    -j host-list   Loose source route along host-list.
    -k host-list   Strict source route along host-list.
    -w timeout     Timeout in milliseconds to wait for each reply.
setup dump  -m [mode] -f <fil>
  mode    : 0-3
            0 : No Dump
            1 : MAC Header Only
            2 : MAC Header and Frame Header
            3 : All
  fil     : 0-2
            0 : Show only My address
            1 : All
            2 : Broadcast Frame hidden dump
setup reg   -r <addr> -v <data>
  NoOption   : display register setting
setup ch    -f <freq> -c <channel>
  Argumet freq or ch
  freq    : 2412/2417/2422/2427/2432/2437/2442/2447/2452/2457/2462/2467/2472/2484/
            5180/5200/5220/5240/5260/5280/5300/5320/5500/5520/5540/5560/5580/5600/
            5620/5640/5660/5680/5700/5475/5765/5785/5805/5825
  channel : 1`14,36/40/44/48/52/56/60/64,100/104/108/112/116/120/124/128/132/136/
            140/149/153/157/161/165
setup frame -l <macl> -u <macu> -b <body> -s <size> -t <tid> -r <rate>
            -p <power> -a <ack> -m <mcs>
  NoOption   : display frame setting
MAC ADDRESS XX:XX:YY:YY:YY:YY
  macl (hex) : 0xXXXX
  macu (hex) : 0xYYYYYYYY
  body       : 0xZZ   MAC Frame Data
  tid        : 0-65535
  rate       : 1/2/5/6/9/11/12/18/24/36/48/54(Mbps)
  power      : 0-255
  ack        : 0/1 (Normal/No ack)
  mcs        : 0-7
send pn    -r <rate> -m <mcs> -p <preamble> -g <gi>
  mcs      : 0-7
  preamble : 0/1 (Long Preamble / Short Preamble)
  gi       : 0/1 (Normal GI / Short GI)
send frame -n <count> -i <interval>  -s <sifs> -r <rifs> -e <enc>
  count    : 0-65535
  interval : 0-65535 (msec)
  sifs     : 0/1 (SIFS Burst Invalid / SIFS Burst Valid)
  rifs     : 0/1 (RIFS Burst Invalid / RIFS Burst Valid)
  enc      : 0 : None
             1 : WEP
             2 : AES
             3 : TKIP
send help
sd buffer [-d | -s]
  -s  : Single buffer
  -d  : Dubble buffer
sd clk ???
  ???  : SD_CLK_CTRL
sd update [filename]
  filename  : file name
sd fread  [filename]
sd gcmd   [number] <arg>
  number   : XX (dec)
  arg      : Command dependent
sd dcmd   [number] <arg> <size>
  number   : XX (dec)
sd clear  [sector] [count]
  sector  : clear sector
  count   : sector count
sd acmd    [number] <arg>
  number   : XX (dec)
sd cmd    [number] <arg>
  number   : XX (dec)
sd write  [sector] <count>
  sector  : write sector (over 0x100)
  count   : sector count (If no <count> continue writing until you issue CMD12)
sd read   [sector] <count>
  sector  : read sector
  count   : sector count (If no <count> continue reading until you issue CMD12)
wlan rate <rate>
  NoOption : display rate setting
  rate     : 0  auto
             1/2/5/6/9/11/12/18/24/36/48/54 (Mbps:11bg)             0-7 (MCS:11n)
wlan obss <0/1>
wlan ap [ssid] [channel] [mode]
  ssid     : 32 strings(max)
  channel  : 1-14
  mode     : 11a/11b/11g/11bg/11n
wlan ibss [bssid] [channel] [mode]
  bssid    : 32 strings(max)
  channel  : 0-14 (0:Auto)
wlan scan -s <ssid> -c <channel> -t <bsstype>
  NoOption : full scan
  bsstype  : 1-3
             1 : access point
             2 : adhoc
             3 : any scan
wlan channel <channel>
  NoOption : display channel
  channel  : 0-14 (0:Auto) channel
wlan enc <mode> <key> <keystring>
  NoOption  : display encrypt setting
  mode      : 0-4
              0 : Open
              1 : WEP40
              2 : WEP104
              3 : WPA
              4 : WPA2
  key       : 0-3
              0 : index / TKIP
              1 : index / AES
              2 : index
              3 : index
  keystring : encrypt key(max 63 strings)
     WEP40    :  5 character fixed(ascii) / 10 character fixed(binary)
     WEP104   : 13 character fixed(ascii) / 26 character fixed(binary)
     WPA      : 8-63 strings
     WPA2     : 8-63 strings
wlan ssid [ssid]
  NoOption : display ssid
  ssid     : 32 strings(max) ssid
wlan mac [macaddr] {-r}
  NoOption : dispaly MAC ADDRESS
  macaddr  : MAC ADDRESS (XX:XX:XX:XX:XX:XX)
  {-r}     : after MAC ADDRESS FlashROM save and reboot
wlan start   <channel>
  channel : 0-14
wlan slottime <0..7>
  0: station 11a/n short slot
  1: station 11g/n short slot
  2: station 11g/n long slot
  3: station 11b long slog
  4: ap 11a/n short slot
  5: ap 11g/n short slot
  6: ap 11g/n long slot
perf udp tx   [ipaddr] <count> <size> {burst}
perf udp rx
  ipaddr : X.X.X.X
  count  : Xs/Xm/Xh/X  (sec/min/hour/num)
  size   : def/big/num (num<=14600)
  burst  : Non-Blocking only
  cl   : TCP client
  clnb : TCP client Non-Blocking
  sv   : TCP server
  svnb : TCP server Non-Blocking
  cs   : TCP client & server
  csnb : TCP client & server Non-Blocking
wps credential {-c} <select>
  NoOption : display Credential
  {-c}     : Credential clear
  select   : 0-5
wps assoc  <mode>
  NoOption : display Association mode
  mode     : auto / manual
wps pincheck  <pin>
  NoOption : display PIN code
  pin      : PIN code (8 character fixed)
wps pin  <pin> <ssid>
show help
show reg -r <addr>
show ch
show mac
show mep
show time
TELEC commands
show
stop help
stop frame
stop pn
stop
setup reg   -r <reg:hex> -v <val:hex>
macsend r <rate> -c <cipher> -a <ack> -n <count> -t <tid> -h <channel> [macaddr:hex]
  rate    : 0 auto
            1/2/5/6/9/11/12/18/24/36/48/54 (Mbps)
  cipher  : no/wep/aes/tkip
  ack     : ack/no
  count   : 1-65535
  tid     : 0-65535
  channel : 1-14
  macaddr : XX:XX:XX:XX:XX:XX
MAC frame send
macsend
reboot system
reboot
ping [ipaddr] <count> <size>
  ipaddr : X.X.X.X
  count  : 1-65535
ip [ipaddr] {mask [m_addr]} {gw [gw_addr]}
  NoOption : display ip setting
  ipaddr   : X.X.X.X
  m_addr   : X.X.X.X
  gw_addr  : X.X.X.X
stat <NoOpt/clear/stack>
show status
stat
dump [addr] {-l length} (round 4byte)
  length(hex) : 0xYYYYYYYY
mod [addr] [data:hex] {-l length:hex} (round 4byte)
  length(hex) : 0xZZZZZZZZ
print [onoff]
  onoff    : on / off
sleep {-bb <bb>} {-host <host>} {-rxen <rxen>} {-rfshdn <rfshdn>} {-deep <deep>} {-clk <clk>}
  bb     : 0/1/2
           0 : MAC layer reset
           1 : MAC layer normal
           2 : MAC layer clock stop
  host   : 0/1
           0 : host clock stop
           1 : host clock normal
  rxen   : 0/1
           0 : RX control off
           1 : RX control on
  rfshdn : 0/1
           0 : RF control off
           1 : RF control on
  deep   : 1-65535
  clk    : 0/1
           0 : External clock off
           1 : External clock on
factory -mac <mac address> -code <manufacture code> -f0 <Traceability-0> -f1 <Traceability-1>
        -agcuse <1:use, 0:Unuse> -agcdsss <ch1agc ch2agc..ch11agc> -agcofdm <ch1agc ch2agc..ch11agc>
        -agcofdm <ch1agc ch2agc..ch11agc> -tbase <ch1TSSIbase ch2TSSIbase..ch11TSSIbase>
        -toffset <DSSSoffset OFDMoffset MCSoffset> -e(erase information)
        -iquse <1:use, 0:Unuse> -txiq <OFDMI OFDMQ DSSSI DSSSQ>
pw <bboff/bbon/anaoff/anaon/rfoff/rfon>
ps [on/off]
ftpscert [filename]
ftpsdel [-p <port>] -m <mode> <address> <user> <password> <filename>
  mode: 0:Implicit 1:Explicit
ftpsren [-p <port>] -m <mode> <address> <user> <password> <source> <destination>
ftpsls [-p <port>] -m <mode> <address> <user> <password> <directory>
ftpsput [-p <port>] -m <mode> <address> <user> <password> <server file> <local file>
ftpsget [-p <port>] -m <mode> <address> <user> <password> <server file> <local file>
ftpdel [-p <port>] <address> <user> <password> <filename>
ftpren [-p <port>] <address> <user> <password> <source> <destination>
ftp rename
ftpls [-p <port>] <address> <user> <password> <directory>
ftpput [-p <port>] <address> <user> <password> <server file> <local file>
ftp upload
ftpget [-p <port>] <address> <user> <password> <server file> <local file>
ftp download
nbios [opt]
  opt    : start / stop / stat
dhcpc [opt]
  opt    : start / stop
dhcpd [opt]
level <arg>
  arg  : NoOption : display mode setting
         1048     : developer
         2        : factory
         1        : enduser
Jarrett wrote 05/01/2015 at 22:22 point
Grabbing the register settings (possibly via setup reg) might go a long way in figuring out what kind of architecture this chip is
