Basic Pulsed Neural Network Simulation
A simulation of a basic pulsed neural network, just slightly different than a traditional neural network.
A software simulation of a pulsed neural network written in python. It's only a single neuron simulation, with three synapses. It also will plot the output using the matplotlib library.
Currently there are two parts to this project. The first is to write the simulation software, and the second is to write a simple program to plot the outputs with reference to the input times.
  • The Basic Functions
    JangoJungle06/09/2015 at 01:21 0 comments
    During my free time in the past few weeks I've worked on my code, so here's a semi-fleshed out skeleton of the code so far. It will also be on Github in the coming weeks. There's a couple of modifications to do, specifically, a better and more thorough plot of not just the neuron pulse times, but also the synaptic event times, and also the projected pulse time calculations need a little tweaking.
    # Neural Network Model
    # This program will simulate an event driven model of a pulsed neural network.
    __author__ = 'JangoJungle'
    from numpy import *
    import random as rand
    import matplotlib.pyplot as plt
    # A quick function to get the synapse state form for plotting  -- Not Used Yet
    def get_state(w, t, a):
        stateraw = Decimal(w - w * abs(t - a))
        index = 0
        for x in stateraw:
            if x <= 0:
                stateraw[index] = 0
            index += 1
        return stateraw
    # declare/initialize variables
    # other variables
    next_event_time = 0
    current_time = 0
    fault = 9999999
    count = 0
    interval = linspace(0,49,50)
    # synaptic variables
    synaptic_weights = r_[[1, 1, 1]]
    state_of_synapses = r_[[0, 0, 0]] # 1 for up, -1 for down, 0 for idle
    synaptic_delays = r_[[rand.randint(0, 3), rand.randint(0, 3), rand.randint(0, 3)]]
    synaptic_event_times = r_[[1, fault, 1]] # start the trigger and pulse train [pulse train, neuron output, trigger]
    synapse_connection_matrix = r_[1, 1, 1]
    # neuron variables
    previous_activity_slope = r_[0]
    current_activity_slope = r_[0]
    threshold = 1.5
    neuron_pulse_times = r_[fault]
    neuron_connection_matrix = c_[[0, 1, 0]] # only one column: only one neuron, connected to synapse 2
    pulse_points = linspace(0,0,50)
    # Start loop:
    while (count < 50):
    	# Go to next event time
    	current_time = next_event_time
    	# Calculate the Next Neuron firing time -- how to adjust this for multiple neurons?
    	current_activity_slope[0] = sum(state_of_synapses*synaptic_weights) + previous_activity_slope[0]
    	if current_activity_slope[0] > 0:
    		neuron_pulse_times[0] = threshold/current_activity_slope[0] + current_time
    	else:
    		neuron_pulse_times[0] = fault
    	previous_activity_slope[0] = current_activity_slope[0]
    	# Find the next event time and type
    	next_synapse_event_time = min(synaptic_event_times)
    	next_synapse = argmin(synaptic_event_times) 	# note: argmin returns a 1d index
    	next_neuron_firing_time = min(neuron_pulse_times)
    	next_neuron = argmin(neuron_pulse_times)
    	next_event_times = r_[[next_synapse_event_time, next_neuron_firing_time]]
    	next_event_time = min(next_event_times)
    	event_type = argmin(next_event_times) 	# 0 for synapse, 1 for neuron
    	# Do required operations for each event type
    	if next_event_time != fault:
    		# If it's a synapse event time, update the states
    		if event_type == 0: 	# synaptic event == 0
    			# Update states
    			if state_of_synapses[next_synapse] == 0:
    				state_of_synapses[next_synapse] = synaptic_weights[next_synapse]
    				synaptic_event_times[next_synapse] += 1
    				print ('Synapse {} is firing.'.format(next_synapse))
    			elif state_of_synapses[next_synapse] == synaptic_weights[next_synapse]:
    				state_of_synapses[next_synapse] = -synaptic_weights[next_synapse]
    			elif state_of_synapses[next_synapse] == -synaptic_weights[next_synapse]:
    				state_of_synapses[next_synapse] = 0
    				synaptic_event_times[next_synapse] = fault
    				# reset the pulse train if it's the pulse train
    				if next_synapse == 0:
    					synaptic_event_times[next_synapse] = (2 + current_time + synaptic_delays[next_synapse])
    		# If it's a neuron firing time, reset the synapses, find all the synapses this neuron is connected to
    		# and then update those synapses
    		if event_type == 1: 	# neuron firing = 1
    			print ('Neuron is firing.')
    			# reset synapses
    			state_of_synapses[0] = state_of_synapses[1] = state_of_synapses[2] = 0
    			synaptic_event_times[0] = synaptic_event_times[1] = synaptic_event_times[2] = fault
    			# find all the synapses this neuron is connected to and update them
    			connected_synapses...
View project log
JangoJungle wrote 05/04/2015 at 14:55 point
Thank you! And thanks Bruce Land for the links! Looks like you're heading the direction I want to go with this: Hardware. That's great! Good work!
zakqwy wrote 05/03/2015 at 18:28 point
Great project idea!
