The Basic Functions
A project log for Basic Pulsed Neural Network Simulation
A simulation of a basic pulsed neural network, just slightly different than a traditional neural network.
jangojungleJangoJungle 06/09/2015 at 01:210 Comments
During my free time in the past few weeks I've worked on my code, so here's a semi-fleshed out skeleton of the code so far. It will also be on Github in the coming weeks. There's a couple of modifications to do, specifically, a better and more thorough plot of not just the neuron pulse times, but also the synaptic event times, and also the projected pulse time calculations need a little tweaking.
# Neural Network Model
# This program will simulate an event driven model of a pulsed neural network.
__author__ = 'JangoJungle'
from numpy import *
import random as rand
import matplotlib.pyplot as plt
# A quick function to get the synapse state form for plotting  -- Not Used Yet
def get_state(w, t, a):
    stateraw = Decimal(w - w * abs(t - a))
    index = 0
    for x in stateraw:
        if x <= 0:
            stateraw[index] = 0
        index += 1
    return stateraw
# declare/initialize variables
# other variables
next_event_time = 0
current_time = 0
fault = 9999999
count = 0
interval = linspace(0,49,50)
# synaptic variables
synaptic_weights = r_[[1, 1, 1]]
state_of_synapses = r_[[0, 0, 0]] # 1 for up, -1 for down, 0 for idle
synaptic_delays = r_[[rand.randint(0, 3), rand.randint(0, 3), rand.randint(0, 3)]]
synaptic_event_times = r_[[1, fault, 1]] # start the trigger and pulse train [pulse train, neuron output, trigger]
synapse_connection_matrix = r_[1, 1, 1]
# neuron variables
previous_activity_slope = r_[0]
current_activity_slope = r_[0]
threshold = 1.5
neuron_pulse_times = r_[fault]
neuron_connection_matrix = c_[[0, 1, 0]] # only one column: only one neuron, connected to synapse 2
pulse_points = linspace(0,0,50)
# Start loop:
while (count < 50):
	# Go to next event time
	current_time = next_event_time
	# Calculate the Next Neuron firing time -- how to adjust this for multiple neurons?
	current_activity_slope[0] = sum(state_of_synapses*synaptic_weights) + previous_activity_slope[0]
	if current_activity_slope[0] > 0:
		neuron_pulse_times[0] = threshold/current_activity_slope[0] + current_time
	else:
		neuron_pulse_times[0] = fault
	previous_activity_slope[0] = current_activity_slope[0]
	# Find the next event time and type
	next_synapse_event_time = min(synaptic_event_times)
	next_synapse = argmin(synaptic_event_times) 	# note: argmin returns a 1d index
	next_neuron_firing_time = min(neuron_pulse_times)
	next_neuron = argmin(neuron_pulse_times)
	next_event_times = r_[[next_synapse_event_time, next_neuron_firing_time]]
	next_event_time = min(next_event_times)
	event_type = argmin(next_event_times) 	# 0 for synapse, 1 for neuron
	# Do required operations for each event type
	if next_event_time != fault:
		# If it's a synapse event time, update the states
		if event_type == 0: 	# synaptic event == 0
			# Update states
			if state_of_synapses[next_synapse] == 0:
				state_of_synapses[next_synapse] = synaptic_weights[next_synapse]
				synaptic_event_times[next_synapse] += 1
				print ('Synapse {} is firing.'.format(next_synapse))
			elif state_of_synapses[next_synapse] == synaptic_weights[next_synapse]:
				state_of_synapses[next_synapse] = -synaptic_weights[next_synapse]
			elif state_of_synapses[next_synapse] == -synaptic_weights[next_synapse]:
				state_of_synapses[next_synapse] = 0
				synaptic_event_times[next_synapse] = fault
				# reset the pulse train if it's the pulse train
				if next_synapse == 0:
					synaptic_event_times[next_synapse] = (2 + current_time + synaptic_delays[next_synapse])
		# If it's a neuron firing time, reset the synapses, find all the synapses this neuron is connected to
		# and then update those synapses
		if event_type == 1: 	# neuron firing = 1
			print ('Neuron is firing.')
			# reset synapses
			state_of_synapses[0] = state_of_synapses[1] = state_of_synapses[2] = 0
			synaptic_event_times[0] = synaptic_event_times[1] = synaptic_event_times[2] = fault
			# find all the synapses this neuron is connected to and update them
			connected_synapses = where(neuron_connection_matrix[next_neuron])[0]
			for synapse in connected_synapses:
				synaptic_event_times[synapse] = current_time + synaptic_delays[synapse]
			neuron_pulse_times[next_neuron] = fault
			if next_synapse == 0 and state_of_synapses[next_synapse] == 0:
			# update the pulsetimes array to hold these new times:
			pulse_points[count] = 1;
	# print out some test data
	print ('-- SS     --          SET          --     NET   --   CT')
	print state_of_synapses, ' -- ', synaptic_event_times, ' -- ', next_event_time, ' -- ', current_time
	print ('\n')
	# advance the count
	count += 1
# show the plot of the pulse_points
plt.plot(interval, pulse_points, '+r')
plt.axis([-1, 50, -1, 2])
plt.show()
This code currently generates plots that look like this:
Essentially all this is showing is at which counts the neuron is firing, 1 being a pulse. At each count in the code, it updates to the next event time, and prints out if the neuron pulses here. So what needs to be cleaned up is instead of going by count in the x axis, I need to switch it to time. Easy switch, but one step at a time.
