My PCBs arrived at last, so I can build the final prototype, with much simpler hardware.
The main modification is in True RNG hardware - istead of external white noise generator, which also worked fine, now I use the uninitialized internal RAM state. I described that process at http://hackaday.com/2015/06/29/true-random-number-generator-for-a-true-hacker/, so I won't write about it here.
I have built six units (that much I promissed to my friends), and everything works great. Here is the first photo:
Voja Antonic
Those orange PCBs look very nice! Where did you find them?
Ordered from Accredo, but most suppliers offer different colours today.
They sure do, but I've never seen orange ones.
Hi!
When I try to build I get four warnings:
Warning[202] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 521 : Argument out of range. Least significant bits used.
Message[311] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 735 : Operand of HIGH operator was larger than H'FFFF'.
Warning[202] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 774 : Argument out of range. Least significant bits used.
Warning[202] C:\USERS\LOND\DOCUMENTS\MPLAB\PASSWORD_MANAGER\MANAGER.ASM 779 : Argument out of range. Least significant bits used.
The build produce a HEX-file, but the password listing function doesn't work :(
/// Marcus
Yes, it's because the default radix is hex.
If you use MPLAB (not MPLABX), then try this:
Project/Build Options/Project/MPASM Assembler, then check
Disable Case Sensitivity, and Default Radix = decimal
If you use MPLABX, find the equivalent to preset default decimal
Tanks!
Now it's working :D :D
/// Marcus
Sorry, memory error in my head :) Now it's there
http://www.voja.rs/PROJECTS/Password%20Manager/0_intro.htm
You can select RNG type and MCU type at the beginning of the source file.
Default is "software RNG" and "PIC18F24K50"
Will source files be released for version B at some stage?
