Working Clock hanging on the wall
A project log for Swifty's Relay Clock Project
24 hour clock made with relay logic
swiftythefox001SwiftyTheFox001 05/03/2018 at 19:323 Comments
ITS DONE!
Final Clock on The Wall
Yes, these are my hands...
The ESP is sitting on the back doing its job getting the time for several days now. I slightly altered the NTP protocol example within Nodemcu's arduino library. The dots are only blinking after a reset to indicate WIFI and NTP status.
I even added a last minute feature: A daylight saving time jumper that chooses the right UTC offset after resetting the clock. Yes, I could have written a smarter code that checks if it is time to switch, but I was too lazy. I don't want to poll any sites regularly as well for parsing this information, so resetting should do it for the moment until I come up for a better idea.
Stuff that is still on the todo list for when I am bored by other stuff:
The promised video is missing as well and I might post more about the way I did the diffusors for the seven segment displays. They did not end up as smooth or easy as I intended, but I am still happy with the outcome.
Dillon Nichols wrote 12/27/2018 at 13:00 point
Can you share your code? I also made a clock project and I'm not completely satisfied on how the NTP time synchronizes with my clock time on the ESP. Maybe your code can help me? Thanks! https://mylifeasa.tinkerer.us/unix-time-clock-57b17d05442e
SwiftyTheFox001 wrote 01/02/2019 at 07:31 point
Sure! I was basically using the ESP example code with a trick. I'll post a log on how things are done with the time keeping with a small video. The code is still power hungry since I do not use any sleep function yet, but I guess you know how it is when stuff works and other projects need also attention :)
Dillon Nichols wrote 01/02/2019 at 12:29 point
Oh yes, I know that feeling exactly. Thanks in advance!
