EMDrive/satellite
Developing a small fuelless microwave thruster
The EMdrive is a new type of thruster - recently invented by Roger Shawyer & Guido Fetta.
Unlike other propulsion systems which need to repel mass to produce thrust, the EMdrive can convert electrical energy into thrust directly.
There are endless uses for an EMDrive - in terrestric and in space applications.
A working EMdrive would start a revolution in spaceflight, enabling manned deep space exploration.
Several builds have been made worldwide (eg Chinese University, NASA), many show positive results. This topic is still quite new and needs a lot of research.
Most EMdrive builds work with frequencies around 2.4 GHz because a high power RF source for them can be made out of a microwave oven magnetron.
My attempt is is to build one which works with 24GHz, which reduces the form factor significantly and makes it possible to be used in small satellites.
A so small EMdrive could be flown to space for 20000$ on a pocketqube satellite.
OVERVIEW
The EMdrive is derived from a closed cylindrical microwave waveguide. The main difference is that one end is larger than the other. When RF is fed into the cavity and a resonance is achieved - according to Shawyer a thrust force will occur.
The first builds have not been summarized due to documentation cleanup process
EMDrive V3
The V3 is a silver cavity build, fed by a fully controllable RF source capable of beeing tuned between 22 and 26 GHz.
The reflected power can be measured in amplitude and phase.
First measurements with acoustic vibrations (by OOK modulation of the RF source) show a force near the designed target resonance frequency. The last experiment is reproducible and shows clear signals. Further tests must be performed to check for directivity of the force.
PS: Many many thanx to all the people who gave us very helpful hints how to improve the system. It has been an exciting ride for us until now, and we hope to provide a functional Baby-EMdrive soon
Special thanx go to TheTravellerEMD, Marvin Macportain, Keegan Reilly, Aurelio Chargb Ramos
EMDrive V4
This build was a complete integrated version which has been tested at the TU Dresden with Prof. Tajmar.
It should have been the flight version for our satellite in case the test would heve been more successful.
We had thermal issues during testing, with temperatures of the amplifier rising up to 90°C.
This led to a massive power derating in the amp.
We had to reduce power to keep the temperature low, so the final force was only slightly above the scale´s resolution.
Other effect like lorentz forces and thermal deformation had a significant pattern in the measure plot.
Tests have been made for 0°, 180° and 90°
Results are not for publilcation yet - we will perform further tests with version 5.
EMDrive V5
This is a development unit - derived from the V4 - which is intended to be tested at TU Dresden. It has some improvements to solve the problems that we had during testing of the V4.
It has an amplifier with better efficiency and is well thermally coupled to the casing for better heat management.
The new silver cavity geometry has an improved shape based on a proposal in Shawyer´s actual patent paper.
This shape will ensure that the pathlengths of the reflected waves on the longitudinal axis of the cavity is always kept to a multiple of lambda/2 of the resonance frequency.
  • New kind of thruster in development
    Paul Kocyla07/19/2017 at 20:34 1 comment
    Just a quick update after a long time:
    The Dresden University will probably continue measurements on the BabyEMDrive thruster with an improved torsion scale. It can resolve 20nN.
    Please check out another promising technology for propellantless propulsion. I decided to share the development and tests on a Mach Effect Thruster:
    https://hackaday.io/project/26013-mach-effect-thruster-xperiments
  • Tests
    Paul Kocyla03/23/2017 at 21:20 1 comment
    In February the EMDrive V6 has been under test on the Technical University Dresden.
    As the pretest-board didn´t output the expected power, I made a quick redesign right before the test date.
    The output after a day in vacuum was around 500mW, that´s "only" 3dB less than the desired 1000mW. Not so bad for a simple 4-Layer board.
    Here is the board inside the scale box:
    I am not allowed to publish detailed results, but some information upfront:
    The thermal drift was much bigger than the possible thrust - anyway the force is depending on the frequency and seems - I say seems because that´ s only a quick observation - to be proportional to the amplitude of the resonance peaks.
    I was only able to spend two days in Dresden so the following long duration tests has been made without my presence.
    Possible forces are lower than 0.1µN, it´s still not 100% to say without eliminating the thermal drift, so we have to wait until this problem is solved.
    The thermal drift shows always in the same direction and disturbs the interesting signal into uncertainty. So thrust is not confirmed but also not busted yet.
    From my side - the Baby EMDrive is completed, unless an affordable amplifier with a significantly higher power appears.
    There is an IAC abstract from Prof. Tajmar submitted about this EMDrive with details available on the conference beeing held in September this year in Australia.
    Thanx to the many interesting discussions and suggestions.
    Special thanx go to Prof. Tajmar, Matthias Koessling and Marcel Weikert for making the measurements possible, and Dave, who boosted the project by financial help - hope we get some thrust out of it so we can send it to space.
  • Pre-Test smulations
    Paul Kocyla02/05/2017 at 16:18 1 comment
    Jamie (monomorphic) ran a simulation on the new EMDrive V5 cavity model. Great work and many thanx!
    He detected two modes - would correspond with my two resonance peaks on the real thing.
    Kein automatischer Alternativtext verfügbar.
  • New board ready for testing
    Paul Kocyla02/02/2017 at 22:42 3 comments
    The last board showed some power leak. The expected power could not be reached. It even degraded to 40mW - bad. Now I made a new board with better connectors and more careful routing which is ready for testing in Dresden.
    It is prepared for the highly sensitive scale and can deliver more than 200mW with 24GHz at 85°C (after cable- and connector lossed), so we should not get thermal issues this time. The ALU-Plate will be also fixed to the scale for better heat dissipation.The cavity is new (blogged about it before). It shows two clean resonance peaks at which we will test for thrust.
    Sweeps will also be made in case there are some other phenomena which may occur beside the two resonance frequencies.
    For an eventual integration into a satellite, the board can find and track the resonance peaks automatically.
    I´ll make a 360° video of the test preparation in Dresden (if allowed).
  • Measurement followup
    Paul Kocyla01/06/2017 at 06:07 1 comment
    Improvement in cavity resonance after simplifying the feed antenna:
    In the previous measurements I soldered a stub to the feed connector to reach lambda/4.
    In this configuration, this stub is missing. The feed pin is shorter than lambda/4 and its angle is the angle of the cone wall.
    There are only two peaks now, the first was also visible before, the second has a more narrow bandwidth and higher amplitude.
    Probably these peaks represent two different cavity excitement modes in this frequency range.
    We will track both of them in the next test session.
  • Cavity V5 measurements
    Paul Kocyla01/03/2017 at 21:19 5 comments
    Here is the setup:
    The EMDdrive V5 board is connected to the cavity´s feed antenna (lambda/4 stub).
    A shorted antenna is used as feedback port which is connected to a power sensor.
    First, I measured the amplifier´s performance by connecting it directly to the power sensor.
    Here are the results:
    At over 23.5 GHz the power is over 100mW - hmmmm it´s a 1000mW amplifier, so that´s not that good, the board is probably not perfectly designed, cables and connectors have losses. The sensor has a 20dB attenuator (compensated calculations for that) and a SMP to 2.92mm adapter, they will probably also cause some losses. So let´s say it´s around 150mW at the working frequency range.
    Now comes the interesting part: The feedback port is connected to the sensor, and frequency sweeps are performed. It´s basically a scalar network analysis.
    First, I left the cavity opened - this means the big endplate was not connected.
    Here is the result - flat, almost no feedback. That´s not surprising, should be like this:
    Look what happens when the big endplate is attached:
    We get three main peaks. Two strong and one weak - and some smaller artefacts.
    I assume the small disturbances are caused by the antennae destroying the optimal shape of the cavity.
    When you look at the power level, it seems that the feedback antenna is sucking all the power out off the cavity, not good, it was probably too long - but better starting off too long than too short. So I cut the feedback antenna shorter, from around 1.7 mm to 1mm (approximately). Here´s the result:
    That´s better. The feedback antenna now sucks 40mW instead of 100mW. That´s better, but still too much.
    Now I cut the antenna to the ground, it´s just a pin in the hole, but the result seems ok:
    Note that the V/div is now 20.0mV instead of 200mV, so it´s sucking just 10mW now.
    Probably some room for improvement here - let´s see, but that´s acceptable.
    BTW before the trolls cry again because of missing axis labels: The two last pictures have same labeling than the third last - I´m just too tired to insert them - have a newborn baby now and a full time job: X:FRQ sweep, Y: power 10mV <=> 1mW
  • EMDrive V5 and cavity prepared for testing
    Paul Kocyla01/02/2017 at 20:48 0 comments
    New EMDrive cavity and board prepared for measurements.
    A precise power sensor, cables (just assembled), adapters and attenuators are all rated for 26GHz.
    I will be able to tell soon exactly how much power the amp is delivering and will be able to measure the cavity properties and resonance condition.
    After these tests I will optimize the feed antenna for maximum power delivery. I will try dipole and loop.
    The cavity has two ports: One with the feed antenna at lambda/4 distance to the big plate and another with a short stub for feedback.
  • Equipment update
    Paul Kocyla12/22/2016 at 08:52 0 comments
    New member in the lab family: A precision power measurement device.
    This device is capable of measung power qualitatively up to 26GHz.
    The funny thing is that although the design comes from 1975, it´ s still in use today and it still has its price. It´s the only thing you can buy to achieve the measuring precision for these frequencies which doesn´t have the price of a new familiy car - 40 years later. At the time of release it was different.
    Sensor head is the 8485a - was lucky to shot one on ebay for half the price they usually go.
    But now finally we get exact measurements for the EMDrive, which will help to optimize the overall design.
    The EMDrive itself will get its own power meter on board - in form of a small chip with less accuracy but good enough to do the job. But until then, this buddy will help to get qualitative results.
    The 26GHz equipment is quite expensive, for example a simple 2.92mm to SMP adapter costs over USD 70 - but it´s important to have the connectors and cables rated for the max. frequency, because in other cases the frequency response of the devices will have notches. Imperfections in the connectors lead to resonances and reflections inside the connectors, the connectors act like a weak cavity.
  • Cleaning up
    Paul Kocyla12/17/2016 at 18:54 0 comments
    The "Flying an EMDrive" project has been removed due to maintenance overhead.
    This doesn´t mean that the EMDrive will not fly - in fact we got a partnership which will make a launch available soon - stay tuned :)
    More details will come later - after we signed the contract
    The things changed a little bit now. We had a test session at TU Dresden with Prof. Tajmar and will establish a lasting partnership.
    The test results are not to be published yet due to an agreement, but what I can say is that the force was not high enough for a reasonable orbit test. The reasons were thermal issues in the high vacuum which caused the amplifier´s TX output power to degrade.
    I made a newdesign with a more efficient amp in an externall box which can be thermally cupled to the scale.
    Here´s the setup:
    I invested some of the funded money in a good used but affordable test equipment going up to 26GHz and will make a careful redesign for a next version V6.
    The paperwork for the satellite launch has been initiated, there´s a lot to do in 2017.
    I plan to do video blogging on the process. I am also expecting trolling as usual, so only constructive comments will be answered.
    The project page will be cleaned up as many of the first steps to get to the current state are not helpful anymore (learning fails).
    If you still need them then feel free to make a backup.
  • EMDrive V5
    Paul Kocyla11/27/2016 at 20:55 3 comments
    The EMDrive V5 board is assembled.
    The metal box can be attached to the scale body for better heat dissipation as we had heat issues during the testing in Dresden. There is also a more efficient amplifier on board which can delliver twice the power than the version V3.
    Now waiting for the new silver cavity to come.
View all 83 project logs
Shpoople wrote 04/26/2016 at 22:48 point
It's so cool to see people that are much smarter than me running serious experiments on things that seem to violate the law of conservation of momentum, it shows that people are willing to try new ideas.
Xark wrote 04/20/2016 at 22:33 point
Hello, I found this recent article regarding EM drive physics and I thought people interested in this project might find it interesting. https://www.technologyreview.com/s/601299/the-curious-link-between-the-fly-by-anomaly-and-the-impossible-emdrive-thruster/
Paul Kocyla wrote 04/21/2016 at 07:09 point
Thanx. Interesting article.
mr-sunderland wrote 04/17/2016 at 23:27 point
Have you considered lining the cavity with bismuth?
willemstaal wrote 04/15/2016 at 09:43 point
Putting a PTFE or PE dielectric inside without changing too much to the frustrum is quite tricky indeed. . You can try it with a dissasembled ceramic fuse .
You can lead the rf wire trough it and avoid thermal issues too.  Oh, and you can consider a small piece of High-Temperature Control and Instrumentation Cable for the end of the lead.
Conundrum wrote 04/12/2016 at 06:43 point
Hi, I have some 24 GHz modules here originally from intruder alarms.
willemstaal wrote 04/11/2016 at 13:32 point
Cool! It looks sleek!
How did you build the small cap? flat or with a inside coneshape? as Gary's Mod predicted it must be coneshaped to yield any effect..  see image
I also are puzzled with the original build from Roger Shawyer . Whats hidden in this section? a magnet? a induction coil? or something else??
Paul Kocyla wrote 04/11/2016 at 16:26 point
Is there more information about spherical endplates? I think I will need to make a new silver cavity, then I can also print the endplates.
I see a problem however on the antenna side. It´s easy to get the antenna directly from the PCB through the center. Else I will need a short RF rigid cable to get to the center. I am also not using any dielectric. Maybe this would help.
willemstaal wrote 04/14/2016 at 11:52 point
the fact is: Experiments in the UK and China were able to measure thrust without a dielectric insert  because they used much higher input power. In your setup more power will probably melt your frustrum.  The key is in the presentation of the waves. Try to make your gain with the antenna. Maybe a small printed circuit inside the frustrum were you can attach the RF onto.
Paul Kocyla wrote 04/15/2016 at 05:30 point
I want to put a PTFE or PE dielectric inside, but I really don´t know how it will affect the excitation and so which changes to make to the cavity.
electronnja wrote 04/06/2016 at 04:38 point
Yo dude, V4 looks awesome, hopefully it will provide you with more accurate data in the new test environment. But in general it looks sweet.
Paul Kocyla wrote 04/06/2016 at 05:42 point
Thanx. First test has been run, they look good. I will perform two more. If the results are repetitive, I will post the raw data as ASCII and a viewer software for easier browsing.
DIGI wrote 03/30/2016 at 02:21 point
I have concerns over this device and its application.
specially its saftey in relation to this video, both are 'microwaves' at high frequencies.
Jarrett wrote 03/30/2016 at 03:07 point
Your microwave oven, your cellphone, your computer monitor, and your hairdryer all emit microwaves :)
This is very low power. It's like saying that your iPod is dangerous because it has electricity, and this video shows that electricity is unsafe
Paul Kocyla wrote 03/30/2016 at 06:28 point
Depends how you use it. Low power microwaves oscillating in a closed cavity in best case don´t radiate...
willemstaal wrote 04/15/2016 at 10:03 point
As i think of the waves in a closed cavity i often think of letting brandy tumble in a snifter to enhance the flavour.. ;)
hobbesalpha1 wrote 03/24/2016 at 13:24 point
Any video of results #2? Good work. Also, can I get confirmation, you said big end leading? As in if this was to be a rocket engine, the small end would be the one pointing out of the rocket and the big end would be pointing up to the main part of the rocket? Not questioning your results because they are well backed by the data. Just asking because this is a different result then previous EMDRIVE tests, and would thus make it unique. :) Sorta has me excited.
Paul Kocyla wrote 03/24/2016 at 14:44 point
When comparing to a rocket, in the actual results the small end would be the one where the flames come out.
In some earlier tests, I got peaks that showed it the other way around, this confused me, too. But they didn´t occur later, so I assumed they´ve been from another source.
The actual data with modified bias voltage of the amplifier looks different. Now according to the data the big end is leading. But I want make more tests to make sure the actual peaks are not bullshit. But I am scepetical if I can trust this "thrust".
According the videos: The videos look all the same, two LEDs in the dark. The tests duration is about seven hours, the results are only visible in the graph afterwards. I can put them somewhere on a server for download, but don´t have the space yet.
hobbesalpha1 wrote 03/24/2016 at 19:41 point
That is what I thought. Okay, try to see if the "thrust" can continue to be repeated over each new experiment. If anything it is helpful in learning the true direction of motion for the next stage, and if it can be confirmed you might be able to claim a brand new patient as this drive would then be working in a way counter that of the original.
Paul Kocyla wrote 03/25/2016 at 05:41 point
In Shawyers original video it is going in both directions. But his drive had a motorized endplate to change the geometry.
It will go into the endplate with higher group velocity. Depending on the overall geometry this can be also the small plate.
Novice wrote 03/11/2016 at 19:08 point
Good on you for doing this despite it supposedly going against the laws of physics. Keep trying and all the best.
Paul Kocyla wrote 03/12/2016 at 13:27 point
Thanx. I wouldn´t have started it if the Chinese Polytechnical University and NASA had not published promising results. But it seems to work in their labs, and there are interesting theories why it doesn´t break laws of physics - so it was worth a try.
bobbynairn wrote 02/28/2016 at 15:09 point
Cool work,good luck!!
Paul Kocyla wrote 02/28/2016 at 18:08 point
Thanx. Tests are running.
electronnja wrote 02/26/2016 at 21:09 point
Just thought I would compliment you on your objective attitude and attention to detail during your experiments, also you have great documentation and analytical results posted here. Keep up the great work.
It would be awesome to get a test model into 0g.
Also if you can detect thrust on a floating platform, you could totally add a rudder and remote control it for some fun :).
Paul Kocyla wrote 02/27/2016 at 07:05 point
Thank you, I´m trying my best :)
If there is thrust, I´ll try to machine a superconducting cavity made of YBCO - this should be really capable of propelling the platform. The forces now are negligable, I just want to make sure there are any before I proceed.
electronnja wrote 02/27/2016 at 07:34 point
Shouldn't be too hard, liquid nitrogen is pretty easy to get. plus you could magetically suspend it if you wanted.
Paul Kocyla wrote 02/27/2016 at 08:20 point
The hard part will be to mill a pressform for YBCO and cooking the powder itself. I already got an oven which can do 1000°C and stuff for injecting an oxygen flow - still must do the electronics for temperature control.
Then the YBCO must be fabricated, grinded, pressed and oxygen-annealed...
Getting Nitrogen is easo though, i got a dewar tank already.
electronnja wrote 02/28/2016 at 00:52 point
You could always use the prototype you already have as a reverse mold and make a ceramic press form from it. It should hold up to temperature, plus you wouldn't need to mill it. May or may not be feasible, just an idea.
hobbesalpha1 wrote 02/15/2016 at 12:29 point
Also, do you happen to have a gold-leaf electroscope? Was wondering if you could detect any charge change at either the large or small side if the vessel
Paul Kocyla wrote 02/15/2016 at 19:50 point
Unfortunately I don´t have one.
hobbesalpha1 wrote 02/15/2016 at 12:18 point
Great work! Keep it up.
hobbesalpha1 wrote 01/21/2016 at 01:54 point
Got a question, could a stirrer fan help with resonating? I thought about it since you were down for a bit.
It is how they dispersed the microwaves in a microwave oven.
Paul Kocyla wrote 01/21/2016 at 07:23 point
I don´t think so. Made some calculations with Traveller´s spreadsheet and it turns out that even slight variations in the geometry brings the cavity out of the frequency span of the transmitter.
Imho it´s better to adjust the frequency electronically. That´s my plan for the V3 version. I am still waiting for the PCBs.
The new board will (hopefully) have the ability to measure the reflected power in magnitude and phase to be able to find resonance by itself.
http://uspas.fnal.gov/materials/09UNM/ResonantCavities.pdf
On page 8 you can see the phase behaviour of a resonant cavity. If you can measure that, you can tune into resonance.
hobbesalpha1 wrote 01/21/2016 at 22:09 point
Sounds good. :)  Again good to see you back up and running. Going to modify a microwave oven to see if I can make my own microwave thruster. If it works will update you.
hobbesalpha1 wrote 01/17/2016 at 19:04 point
Good to see you back up and running.
DeepSOIC wrote 10/16/2015 at 11:14 point
Some thoughts.
a) the explanation of supposed trust is called "pressure of light". Anything else does not apply, because it will violate newton's third law (something has to get the opposite reaction, and the only something is the RF stream the thruster expels, which is just a flux of photons).
<EDIT>: after following the link @cosmicvoyager posted, I realized that the explanation of the thrust being sought indeed violates Newton's Third Law. See:
https://en.wikipedia.org/wiki/RF_resonant_cavity_thruster
The thoughts that follow are based on "classic" pressure-of-light explanation...</EDIT>
b) looked up the formulas for pressure of light on Wikipedia. the momentum of photon is hv/c. hv is photon energy, so momentum = E/c (c is speed of light). The amount of photons expelled per second is dn/dt=P/E (where P is power), and the force is F=dp/dt=P/c. So simple!
c) in b), I got that the thrust does not depend on frequency. It is in direct relationship with output power, and NOTHING else. So, how about using a light source to generate thrust.. maybe an LED... or maybe an incandescent lamp is even better!
d) the thruster requires buttloads of power to generate any sensible thrust. Where on earth .. I meant .. in space .. are we going to get that much power?
EDIT:
e) For 0.5 watts of power, the thrust is going to be 1.67E-09 N, which is
0.17 microgram-force.
DeepSOIC wrote 10/16/2015 at 18:03 point
But even though I think the idea is quite hopeless, the amount of science and effort put into measuring the thrust is enormous, and that alone makes the project very interesting to me =) Keep up! Detecting the pressure of light is an big achievement on its own.
Paul Kocyla wrote 12/17/2015 at 11:55 point
The frequency becomes an issue if you want to use the Q factor of the cavity to multiply your output. If you hit resonance, you can charge up the cavity with more photons. The force will multiply by the Q factor. The higher the Q, the lower the bandwidth becomes, for superconductive cavities this would be a window of less than 50 kHz range from the resonance frequency.
willemstaal wrote 10/18/2015 at 09:53 point
If thats so easy, we could attach a lightbulb on the back of a spacevessel, turn on a switch and off we go!
Altough.. light is a very odd phenomena. Consider this: we are able to detect light eminating from the other end of the known universe!
So wat repels those particles or waves so long and so fast? It must be something very powerfull! If i emit a sound, it goes not much further that like 20 miles using a very powerfull amplifier. If you switch on a battery powered laserpointer then you  are able to reach the moon with a button cell. amazing.
As a EM Drive is a radiowave generator (we can detect radio transmissions from neutron stars far out in space) it can be possible that the same power that drives light particles might repell the drive, and as the gravitational force is stronger on earth , it obvious we cant see much movement here. (even light cant escape from strong gravity sources, as everyone knows ) so maybe its a good idea to test force measurements on different locations: around the equator and around the polar circle.
cosmicvoyager wrote 12/05/2015 at 12:56 point
"something has to get the opposite reaction, and the only something is
the RF stream the thruster expels, which is just a flux of photons"
It is thought that what is expelled is virtual particles.
https://en.wikipedia.org/wiki/Quantum_vacuum_thruster
DeepSOIC wrote 12/05/2015 at 20:28 point
I have no idea, what are these virtual particles... It feels like no one really knows what they are. OK, if we assume the virtual particles are somewhat real - my conclusions are wrong. =)
hobbesalpha1 wrote 10/04/2015 at 11:59 point
Do you have anything grounding the vessel? Like an electric ground? Also can you test the same vessel except using the covered big plate assembly from the adjustable vessel?
Paul Kocyla wrote 10/04/2015 at 15:59 point
Ground is the battery ground, the platform itself is isolating.
But why should this be an issue? There is no electron/ion emission which could charge up the vessel.
hobbesalpha1 wrote 10/04/2015 at 16:39 point
My thought was to why there was a time limit to the force, as in why is the force decreasing over time. And I wasn't worried about an electron/ion emission as microwaves are non-ionizing, more that if given a medium that the displaced electrons would move away from the places where they can produce the most force over time and return to their place after the system is turned off.
Paul Kocyla wrote 10/04/2015 at 16:47 point
I understand now. The system was switched off between several tests  for recharging batteries. Even a cold start on the next day could not reproduce A1-A2 graphs, but B1-B4 are no problem, they show the same behaviour instantly.
hobbesalpha1 wrote 10/05/2015 at 10:54 point
Reason I asked about the second big plate was that it was covered. My question is do you get a different force profile with a covered big plate?
Paul Kocyla wrote 10/05/2015 at 14:08 point
Do you mean "covered" as not mechanically tuneable? I didn´t measure anything useful with the tuneable steel screw, so I put fixed plates at both ends. All new tests are made with the fixed walls.
hobbesalpha1 wrote 10/05/2015 at 22:49 point
Sorry I might be getting confused, I am referring to the picture above, wherein the big plate appears to be covered on the outside by plastic.
hobbesalpha1 wrote 09/29/2015 at 22:35 point
Well if my theory is correct it might be certain electrons on the inner surface bouncing in between the two surfaces, the inner surface and the outer surface, or to say it better, they are pushing themselves away from the inner surface and causing a ripple effect. Reason it shows like that is that it is the tipping point. As basically we would be creating what actually made the microwaves in the first place, but in reverse. Instead of high energy electrons spinning around a copper or silver cavity making microwaves. We have a vessel, which is just a big cavity of copper, that we are pouring microwaves into, and getting the microwaves back up to resonance inside the vessel. It wouldn't surprise me if by doing so, we are reversing the process. It would also explain why it is easier to make a vessel out of copper, as it would just be a natural limiter as it was a copper cavity on most magnitrons (sorry for the mispell) that makes the microwaves for the bigger vessels. Also sorry for wall of text.
vaygr89 wrote 09/29/2015 at 03:46 point
If we give more power to this, then can we get more power? Can you tell me?
Paul Kocyla wrote 09/29/2015 at 07:33 point
More power would help to overcome the losses, so yes, the force should get higher.
