Cavity Finished
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
paul-kocylaPaul Kocyla 06/04/2015 at 10:535 Comments
Jo finished the cavity - we can perform the first test probably next week.
Paul mc wrote 06/05/2015 at 07:38 point
The size of the cavity must equate to the focal length of the microwave frequencies or you will get a seriously degraded thrust ratio.
Have you worked out what frequency is required? It is my understanding that reducing the cavity size requires much higher frequencies and therefore far more expensive magnetrons possibly even supercooled
Paul Kocyla wrote 06/05/2015 at 09:06 point
We use a modified radar module with 24GHz, but with quite low output power, the cavity is calculated to match the frequency.
Paul Kocyla wrote 06/05/2015 at 05:49 point
It´s 64.7 gramms
simonjwhitaker wrote 06/05/2015 at 01:58 point
where is the decimal point in the scale photo?  clearly it doesn't weigh 6kg
It´s 64.7 gramms
