So I knew the drone was creating a WiFi called JJRC-Something. So in order to capture the traffic the app was sending to the drone I fired up Kali Linux and used aircrack-ng to start a scan.
First stop the network driver in order to use monitor mode.
sudo airmong-ng check kill sudo airmong-ng start wlan0 sudo airodump-ng wlan0mon
