Extended colours
A project log for LED Matrix Shield and library
Got fed up of having to look up the datasheet and code examples when using a matrix with an arduino...
samSam 04/04/2014 at 20:140 Comments
I've now added the ability to utilise both the red and green LEDs at the same time, without rewiring as was required previously.
An example patter can be seen here: https://vine.co/v/MeHrzungLTP
