Xbox One E-Sports Controller
The Ideal FPS Xbox Controller
The Xbox One controller is built fairly well but has a few flaws that might not effect the average gamer however if you play competitive fps games it is very noticeable. This projects goal is to make the ideal Xbox One E-Sports Controller!
There are a couple issues I want to tackle in this project
  • Trigger Responsiveness
  • Button Remapping
  • Unreliable USB Connection
  • 2 × Resistor Any value will do, I use 460 ohm
  • 1 × LM393 Amplifier and Linear ICs / Comparator ICs
  • ​Trigger Responsiveness
    recognizetapia05/08/2015 at 04:28 0 comments
    The issue with the triggers is that you can press the triggers in slightly without actually triggering a button press which causes needed latency when gaming. To combat this I use an added hall-effect sensor for each trigger and use a comparator board I made with the LM393. The Xbox One controller uses hall effect sensors to determine how far the trigger is pushed down hall-effect --> MCU. I place the comparator board in between the the hall-effect and MCU so I can adjust when the trigger "triggers" with a trimmer potentiometer with great accuracy.
    hall-effect --> comparator --> MCU
View project log
isue33 wrote 03/21/2021 at 14:26 point
This console looks so cool. I rally like it and I want to use it for my webpage, you can see here https://allbestelectronicshop.com/
