Why did I use arduino?
A project log for Hardware serial port monitor with WiFi
Arduino connects to the TX line (of a router, RPI) and display serial data on smartphone over WiFi
frenkyFrenky 03/08/2016 at 11:550 Comments
I started this project almost a year ago. At that time arduino core for esp was in pre alpha stage so it was logical to use nodemcu. If you use nodemcu the serial port is already reserved for issuing commands to esp so I could not use it for sniffing traffic.
If I started now I wouldn't use arduino...
I would just flash arduino core on esp8266 and be done with it. It would be a lot easier to make.
