Igniter Cables
A project log for 256 Channel Firework Controller
Use two cheap 16-relay boards to multiplex and remotely control up to 256 channels of firey madness
aleks-clarkAleks Clark 07/04/2015 at 15:410 Comments
Well, this morning finished assembling igniter cables. Definitely going the RJ45 + push lock terminal route next time, something like:
The current process goes like this:
Solder
separate wires on a piece of cardstock
add hot glue
press down
rinse, repeat many times
