BOBBER
Floating ball that detects movement in a household pool and through WiFi notifies the user
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
My idea is to create a system that samples a accelerometer and can detect when a person (IE: child) enters a pool. The device would then connect to the home WiFi and ping the associated user.
The form factor would be the same size and shape as a tennis ball. It would float on the surface balanced such that a small solar panel would always face upwards.
Power budgeting will need to be completed first. I plan on storing power in a small super capacitor. I believe that a low power FPGA can sample the accelerometer and when needed trigger an interrupt on a low power MSP430 to send data over WiFi.
