Uses 2" x 2" format and terminal blocks for Instrumentation Amp. Amp has ability to add RFI filter caps on front end and may work at single and dual supplies. Gain resistors can be experimented with through-hole Mill-Max terminals or more permanently by wrapping leads around turret terminals.
Components
1×
AD8230
Amplifier and Linear ICs / Instrumentation Amplifiers Zero Drift Instrumentation Amplifier
Hey Bil! A DIY kit can be whatever you want it to be. Most often I see boards sold with the SMT parts already soldered on.
