Blackbox is back on Hackaday!
A project log for Blackbox - Tool Changing 3D Printer
high-end open-source printer with a water-cooled tool changer.
marc-schmannMarc Schömann 07/31/2019 at 15:000 Comments
I'm taking part in this year's hackaday prize with the blackbox project, so this project page will be discontinued!
You can find the new project page here: https://hackaday.io/project/166860-multitool-3d-printer-blackbox
I can use every support, it would be great if you like and share this project!
It's been a while since the last Log on Hackaday. The reason is that I had to abandon some cummincation channels in favor of some others. I used the time to build a compelling project page on my website, set up a community forum, and worked hard on getting the fusion files ready. That was a lot of work - and still is - but it's getting easier. Blackbox is now on a path to be a real community-driven open source project with many contributors.
I will post all significant updates on my Blog first and then spread it to different channels including Hackaday. Github won't be further used because it's just painful to use with 3D Files (File Size limit, upload and deleting procedure etc.). Primary source will be the Fusion 360 File where everyone is invited to participate. Fusion has a built-in version system, offers group projects and can directly export BOM files. All that makes it the perfect platform to collaborate.
Source files, BOM and latest Informations https://layershift.xyz/blackbox3dprinter/
Coordination for all builder and contributors is primarily on the Forum and discord
