Repair # 10: MakerBot Replicator 1 Extruder Plunger Spacers
A project log for Home Repairs with a 3D Printer
Since moving into a new home a little over two years ago, we've been fixing and improving things all over
makerblockMakerBlock 02/18/2018 at 05:030 Comments
Date: 1/29/2017
About a year ago my MakerBot Replicator 1 started to have trouble extruding plastic consistently.  After making sure there were no blockages and making sure the filament wasn't to blame, I pulled the extruder apart to find out what had happened.
Years of extruding plastic had worn a groove into the delrin plunger, basically making the extruder much looser than the machine was designed to operate.  The plunger has these thin washers that sit behind it - placed at the factor to optimize the pressure of the delrin plunger against the filament.  I designed these very thin spacer to fit behind the plunger along with the stock washers.
I know you're probably asking - why not just install the extruder upgrade every single other MakerBot operator is using???  Well, that day I had a 3D printer that was able to print (admittedly, poorly) the washers, and could have printed the extruder upgrade, but I didn't have screws, springs, etc needed to assemble the extruder.  This fix got my printer working better almost instantly... and kept it going until the hardware arrived in the mail.  :)
Since this contest entry is really a collection of entries, I've uploaded the STL and OpenSCAD files to Thingiverse here.
