• Here's some code...
    bret.wiebe08/16/2015 at 00:52 0 comments
    Definitely not elegant or optimal, but here's what is presently running this thing:
    #include <SevenSeg.h>
    #include <Wire.h>
    #include <Time.h>
    #include <DS1307RTC.h>
    #include <Adafruit_Sensor.h>
    #include <Adafruit_LSM303_U.h>
    SevenSeg disp(10,12,7,8,9,11,A2);
    const int numOfDigits=4;
    int digitPins[numOfDigits]={5,4,2,6};
    volatile int indexMode = 0;
    char* nounAZ[] = {"lamp", "desk", " car", " dog", " cat", "door", "bike", "shoe", "tree", "shed", "fork", " tea", "hill", " job", "head", "food", " cup", "cafe", " dad", " mom"};
    char* verbAZ[] = {" is", " was", " are", " ate", "goes", "runs", "eats", "wins", "sees", "gets", "puts", "cuts", " had"};
    char* adjAZ[] = {" big", "blue", "tiny", " red", " bad", "good", "easy", " wee", "huge", " mad", " sad", "glad", " rad", "near", " far", " low", "high", "wide", "thin", " hot", "cold", "cool", "warm"};
    int poem1[] = {8, 1, 2, 3, 1, 1, 2, 3, 1};
    int poemLength = poem1[0] +1;
    Adafruit_LSM303_Mag_Unified mag = Adafruit_LSM303_Mag_Unified(12345);
    void setup() {
    disp.setDigitPins(numOfDigits,digitPins);
    disp.setDPPin(13);
    pinMode(3, INPUT);
    attachInterrupt(1, changeMode, FALLING);
    if(!mag.begin())
    // the loop function runs over and over again forever
    void loop() {
    switch (indexMode) {
    case 0:
    for (int pmode=1; pmode<150; pmode++) {
    disp.write("poem");
    delay(10);
    displayPoem();
    break;
    case 1:
    for (int tmode=1; tmode<150; tmode++) {
    disp.write("time");
    delay(10);
    printTime();
    break;
    case 2:
    for (int dmode=1; dmode<150; dmode++) {
    disp.write("dirn");
    delay(10);
    printDirn();
    break;
    void displayPoem(){
    int i = 1;
    int poemLength = poem1[0] + 1;
    while (i < poemLength) {
    int poemIndex = poem1[i];
    if (poemIndex == 1)
    printNoun();
    else if (poemIndex == 2)
    printVerb();
    else if (poemIndex == 3)
    printAdj();
    else
    Serial.println("oops");
    i++;
    for (int j=0; j<=129; j++) {
    disp.write("fini");
    delay(5);
    void printNoun(){
    randomSeed(analogRead(1));
    int numTD;
    numTD = random(19);
    delay(150);
    for (int b=0; b <=100; b++){
    disp.write(nounAZ[numTD]);
    delay(5);
    delay(500);
    void printVerb(){
    int numTD;
    numTD = random(12);
    delay(150);
    disp.write(verbAZ[numTD]);
    delay(5);
    delay(500);
    void printAdj(){
    int numTD;
    numTD = random(22);
    delay(150);
    disp.write(adjAZ[numTD]);
    delay(5);
    delay(500);
    void printTime(){
    tmElements_t tm;
    if (RTC.read(tm)) {
    //delay(1000);
    int hours = tm.Hour;
    int minutes = tm.Minute;
    for (int j=0; j<=333; j++) {
    disp.writeClock(hours,minutes);
    delay(5);
    void printDirn(){
    //disp.write("dirn");
    /* Get a new sensor event */
    sensors_event_t event;
    mag.getEvent(&event);
    float Pi = 3.14159;
    // Calculate the angle of the vector y,x
    float heading = (atan2(event.magnetic.y,event.magnetic.x) * 180) / Pi;
    // Normalize to 0-360
    if (heading < 0)
    heading = 360 + heading;
    for (int c=0; c <333; c++) {
    disp.write(heading);
    delay(15);
    void changeMode() {
    ++indexMode %= 3;
  • PCB beginnings
    bret.wiebe07/29/2015 at 20:28 0 comments
    Just rediscovered Upverter, have started learning the ropes and creating my schematic. The goal is to layout a pcb for the "permanent" version of this thing. I have some protoboards that I could use, but as a large motivation behind this endeavour is to learn new stuff I would prefer to get some experience with producing a pcb layout.
  • Some (more) progress
    bret.wiebe06/26/2015 at 19:32 0 comments
    Here's a schematic of the current setup. Had to do a little connection shuffling to free up digital pin 2 for the external interrupt, using the tact switch to change modes (poem, clock, compass). Next step is to gather the useful parts of my various test sketches into a functioning unit and tweak the poetry portion.
  • Some progress...
    bret.wiebe06/04/2015 at 16:27 0 comments
    The two modules arrived and I assembled the DS1307 RTC kit. The basic code for generating the "poems" is working (still on the Pro Mini). I attempted to compile it for the Teensy-LC but got an error related to the library I'm using for the seven segment display and a warning related to using an array of strings. I'm debating whether to figure these issues out now before proceeding with the Teensy-LC or if I should continue with the Pro Mini and then adapt for the LC later. Any ideas of alternative ways to handle the seven segment display on the Teensy?
  • Parts acquisition
    bret.wiebe05/14/2015 at 16:23 0 comments
    Just ordered the RTC and magnetometer modules. Decided on the LSM303 triple-axis accelerometer and magnetometer from Adafruit as the feature/price factor seemed like the best value. Continuing to sketch ideas about how to use the seven segment display in various ways and reconfigured the circuit-thus-far on the breadboard to make room for the two modules.
