Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Dalek Fez
For the Doctor Who fan
GaliaGalia
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
92
2
2
2
Team (1)
  • GaliaGalia
Join this project's team
hardware
ongoing project
This project was created on 05/11/2015 and last updated 6 years ago.
Description
Google "Dalek" if you don't know what that is. There was an ongoing joke on the TV show "Doctor Who" about fezzes, so I combined the two using an Arduino. Check out the video.
It was a hit on the official 50th anniversary convention! In future versions I'll add modes that control the blinking (button controlled, randomly or using relevant sensors) and perhaps the moving eyestalk.
It is currently controlled with a button and a potentiometer.
Details
Components
  • 1 × Arduino
  • 3 × LEDs Electronic Components / Misc. Electronic Components
  • 1 × Fez Connectors and Accessories / RF and Coaxial Connectors
  • 1 × Servo
  • 1 × Push button
View all 7 components
Log In/Sign up to comment
Sign up with Github
OR
Galia wrote 05/11/2015 at 15:27 • point
Thanks! I embedded the video now, looks much better. I'll do the same on the other project I uploaded - that one doesn't even have an image because it's not designed yet :) (Hackathon project)
I played with a microphone but either it was damaged or it wasn't sensitive enough. Same goes for using vibrations for the LEDs. But I haven't put nearly any time into that yet.
I need to replace the fez first because it's too weak now, with the mechanism glued to the top and with all my testing making the top weak. I'll work on the next one and make it stronger. I also need to resolder everything and possibly replace the Arduino because the servo is acting up for no good reason. THEN I'll start looking at mics again :)
davedarko wrote 05/11/2015 at 14:49 • point
Awesome idea! Btw, you can embed the video on this page by adding the link to the details and hit enter afterwards :) Would be cool to see the LEDs blink when you are talking by adding a microphone, reading out the gain values and use analogWrite for the LEDs.
Smart Home Bot using the IOT technology to control your home appliances remotely through the Internet.
Project Owner Contributor
GO-4 SMART HOME ARDUINO BOT
Ahmed AzouzAhmed Azouz
Simply ctrl your videos and music with a remote control using arduino
Controlling VLC with Arduino
8teims8teims
Emulate an IR remote using Arduino to control your devices with Arduino, add sensors, voice assistant, timer, automation etc!
Automatic Arduino based IR Remote Control
akarshagarwal98akarshagarwal98
i made project, you can control lights fans every thing via Bluetooth or internet on your android mobile, whether you are in your office
home appliance control using andoid
kashi_boy2000kashi_boy2000
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Dalek Fez", please tell us the reason.
Send message
Remove Member
