Modifying the Nixie Tube collars
A project log for Nixie 'Display of Things'
Use a combination of six Nixie tubes with a 16x2 LCD display and Pi2 with Adafruit Proto-Perma HAT to display information.
jon-davies-woodyJon Davies "Woody" 05/12/2015 at 00:422 Comments
I decided to keep the plastic collars on which the tubes sit, but also wanted to option to shine an RGB LED up through the centre of each tube. First task in this case was to drill a hole in each collar.
A bit of finishing was required to get rid of plastic burrs.
Jon Davies "Woody" wrote 09/02/2017 at 14:27 point
Hi Steve,
I used this as a build log for an instructable that is here:
http://www.instructables.com/id/Nixie-Driver-HAT
Hope that satisfies your appetite a bit more :)
Steve Lamb wrote 09/01/2017 at 00:52 point
Any more Progress?? I'd like to see more.
