DualShock controller working
A project log for VerilogBoy - GameBoy on FPGA
A Pi emulating a GameBoy sounds cheap. What about an FPGA?
Wenting ZhangWenting Zhang 04/16/2018 at 03:390 Comments
For the controller, I decided to use the PSX controller (DualShock 1). I know that I could use something like a NES controller, which is probably easier to interface with (?), but I just thought that it might be used in my future projects, having more buttons is probably better. So, as I result, I got a cheap DualShock 1 clone off eBay.
I spent some time writing and testing the driver for it, and now it is working (partially). I am able to read all buttons out, including two analog joystick. However, I am unable to enter the escape mode and manually set it to work under analog mode rather than digital. The controller simply refuse to ACK my 0x44 Set Major Mode command. I guess this is not a big deal, the Game Boy does not even need the analog joystick, and I can always set the mode by pressing ANALOG key.
Here is a screenshot of the oscilloscope showing it working in the analog mode:
And here is a screenshot of it refuse to ACK my 0x44 command:
For more information about the driver itself, please refer to the code.
