On the way designing the hardware
10/22/2018 at 23:40 • 0 commentsFinally I decided to design the hardware for it, rather than just running on the devboard. Here is the short video provides a time lapse of me designing the hardware, and a short introduction to the project.
DualShock controller working
04/16/2018 at 03:39 • 0 commentsFor the controller, I decided to use the PSX controller (DualShock 1). I know that I could use something like a NES controller, which is probably easier to interface with (?), but I just thought that it might be used in my future projects, having more buttons is probably better. So, as I result, I got a cheap DualShock 1 clone off eBay.
I spent some time writing and testing the driver for it, and now it is working (partially). I am able to read all buttons out, including two analog joystick. However, I am unable to enter the escape mode and manually set it to work under analog mode rather than digital. The controller simply refuse to ACK my 0x44 Set Major Mode command. I guess this is not a big deal, the Game Boy does not even need the analog joystick, and I can always set the mode by pressing ANALOG key.
Here is a screenshot of the oscilloscope showing it working in the analog mode:
And here is a screenshot of it refuse to ACK my 0x44 command:
Demo video!
04/15/2018 at 18:16 • 0 comments(Please turn down the volume before play)
Audio
04/11/2018 at 19:47 • 0 commentsI am almost finishing the audio part (depend on how to define audio). Currently all 4 channels are working fine with no audible problems (I am not sure how accurate it really is, but it literally "sounds" good.) The original Game Boy sound system is kind of buggy (See "Obscure Behavior" at http://gbdev.gg8.se/wiki/articles/Gameboy_sound_hardware ), and I am not currently trying to implement these bugs. Since these bugs are inconsistent among different models of Game Boys, I guess not many games are actually making using of these quirks.
There are several things in the audio part worth noting. The first is that the duty cycle. The pandocs and the Game Boy Programming Manual are describing the duty cycle setting totally different. The pandocs is defining the duty cycle to be the percentage is LOW while the GBPM is defining it to be the percentage is HIGH. I guess I would have to do some probing to figure this out.
The next problem is mixing. I am guessing that the GameBoy are using OpAmps to mixing things together rather than using digital adder. Both documents claims that each channel have a dedicated DAC. The presence of the Vin function could also be a suggestion that they are mixing in an analog manner. Also I believe that they are using a PGA to control the volume rather than digital multiplier. (If the mixer is OpAmp, then the volume control could not be a multiplier, after all). But apparently I cannot do this with an FPGA, so I am using adder and multiplier to do the job.
Another problem is the signal sign. Audio processing nowadays usually use a signed number to represent the level. The Game Boy could possibly do the same thing (offset binary, not 2's compliment), but I think they didn't. The reason are this: The advantage of using a signed number is that it would have a constant zero level (Vmax/2), rather than a variable zero level (Vsignal/2), but the disadvantage is that it would be hard to do the volume control. For a square wave, controlling the volume would be easy when it comes to unsigned number: it simply output the volume when the waveform is high, and 0 when it is low. If it is a signed number, we can possibly do the same thing, output Vol/2 when it is high and -Vol/2 when it is low, at a cost of losing 1 bit of volume precision which is undesirable. (The reason is simple, if it is signed number, output would make sense only if Vhigh = -Vlow, this would make some combination of high and low value unusable). As a result, the Game Boy should be using unsigned number rather than signed.
Last, the current design of Sound module is using around 600 Virtex-5 LUTs, expect the number to be higher for Spartan-3E LUTs or Cyclone II LEs. This number include output adder and multipliers.
Working on the PPU...
03/07/2018 at 04:19 • 0 commentsI am trying to implement the PPU according to the "Pixel Pipeline" model as in the Ultimate GameBoy Talk. Currently BG/Window rendering works fine.
GameBoy Boot ROM
02/19/2018 at 00:30 • 0 commentsWhen a GameBoy is powered on, the very first code gets executed is the boot ROM. It will scroll down the Nintendo logo, make a chime, and jump to the cartridge.
So that would be also my start point to test the whole system. Fortunately the boot ROM binary is available only so I do not need to dump it from my GameBoy (it would be very difficult to do so). I also got a copy of disassembled source code.
Unfortunately the source code I got will not pass the assembler, but it is easy to modify to make it work. While I was reading the code, I also added some comments along the way.
In order to test my boot ROM in the emulator I also added a header and some initialization code to make it like a Game ROM which could run in the emulator. Since these things are outside of the Boot ROM area so they would not affect the final output.
Full code available on GitHub: https://github.com/zephray/GameBoy/blob/master/Tools/bootstrap/bootstrap.s
