Triggering the LCD lenses - Success
A project log for Peril-Sensitive Sunglasses
A version of the Peril-Sensitive Sunglasses (as described by Douglas Adams in The Hitchhiker's Guide to the Galaxy)
minimum-effective-doseMinimum Effective Dose 03/25/2014 at 01:572 Comments
The glasses have been disassembled and a basic means of triggering the LCD shutters has been determined.
Each LCD lens has a small mylar ribbon connector going to the main PCB.  There is one at each corner.
For each connector, the inner contact (nearest the nosepiece) is "+" and the outer contact (nearest the lenses) is "-".
A positive voltage through a 1k resistor (with ground on the other contact) was observed to trigger the LCD shutter on the matching side. A resistor was used for some basic current limiting - a minimal nod towards protecting the hardware from something going amiss.
3V was sunglasses-dark, 5V was nearly opaque. Reducing the resistor value had some effect on the observed darkness of the triggered lens, but not as much of an effect as changing the voltage. The LCD triggering appears to be primarily voltage-controlled.
A brief experiment using PWM to drive the trigger signal yielded interesting results.  Using an Arduino, a lens was triggered with a 50% duty cycle [via analogWrite(lcdShutter,127) ] and the lens was observed to be darkened less, and the tint appeared even and stable. Voltage level has an effect on LCD lens darkness, but PWM appears to be a much better way to control "tint level".
Of course, the Peril-Sensitive Sunglasses have no need of half-measures so we won't be needing that, but it's nice to know.
This gives us enough to work with.  We know how to control the shutters now.
Minimum Effective Dose wrote 03/27/2014 at 02:10 point
The LCD shutters need some kind of discharge to lighten up again. When disconnected from the PCB and voltage applied, the lenses remained dark and took a long time to lighten again. Discharging the charge through a resistor made the change back to clear quickly. Leaving the lenses connected to the PCB seems to provide this loading, so I won't be removing the PCB and will just solder direct to the existing connections.
Minimum Effective Dose wrote 03/27/2014 at 02:08 point
Two things to add: the rightmost contacts trigger BOTH lenses. The leftmost contact triggers only the left lens.
