The vest and cape are both roughly based on the patterns for: goo.gl/YwNIj9 and goo.gl/WGzO7P respectively.
The brainstorm and feature wishlist can be found at (crackroot dot org/files/vest dot pdf) and (crackroot dot org/files/cape dot pdf) respectively.
