GSM Camera Server (GM01)
I had an old security Camera around. It's send the images over GSM to a server. Now I'm running my own ;-)
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The Camera has an Sim Card to connect to a Server over GPRS.
VisorTech is running a service but it's down at the moment:
http://www.visor-tech.com/GSM-Kamera-REF-17671-919.shtml
The service is not very secure. It is possible to viel all Fotos without a Passwort (If you know what you are doing ....)
So it was time to run my own server!
There is not much documentation about the Protokoll used. The only thing I found is this PDF:
http://tr.iconcox.com/uploads/soft/140916/1-140916014342.pdf
But there are also some bugs in the firmware of the camera itself. After logging the communication between the camera and the server I was able to build my own server:
