WiFi module information
A project log for Exploring Amazon Dash Button
Documenting Amazon's inexpensive IoT button
dekunukemdekuNukem • 05/18/2015 at 00:05•2 Comments
The WiFi module used in Amazon Dash button is Broadcom BCM943362WCD4. As can be seen below:
The crystal, microcontroller and wifi module are exactly the same.
It is supported by Broadcom's WICED SDK and IDE, which can be found in github here. Definitions and schematics of this particular module can be found here. JTAG headers are broken out in the testpads above so it should be easy to reprogram.
And also if you can register an account, there are tons of information at Broadcom's official website here.
Vitaliy wrote 06/27/2016 at 12:13 • point
https://github.com/lubing521  Do anybody know alt source for
WICED SDK and IDE?
engineer wrote 04/11/2016 at 12:11 • point
The github link that you reference has been taken off github for copy right issues.
