FPV Screen Test
A project log for S500 Quadcopter Build
A Project page for my S500 frame and APM2.6 Quadcopter build, with WiFi firmware loading via ESP8266
AVRAVR 11/11/2015 at 01:133 Comments
Last week I soldered up and tested my FPV screen. This screen gives me the video feed with telemetry data overlayed from the quadcopter's camera. The transmitter and receiver are the generic PAL 5.8GHZ analog set you can find on ebay or alibaba. This test was merely just a power on test, to test the screen wiring, in a later post I will show the transmitter and camera working.
Back cover of the screen, 5.8GHZ PAL receiver attached with command strips, eventually going to make a 3D printed casing to graft to the back of the screen for mounting the PCB of the receiver sans case.
Second hole drilled in place next to stock video cable hole. The second hole is for the power cable that will connect to a battery, the cable is long so the battery can be placed in my back pocket.
All put back together and powered on. Note red LED on 5.8GHZ receiver.
Bottom view, showing wiring from radio receiver into screen, and power cable.
Default screen when no signal is detected on the input. The screen has two analog inputs switchable by the buttons on the front or included remote.
Thats all for the screen test, radio and camera test in next update.
Richard Hogben wrote 11/11/2015 at 01:17 point
Is this just a field fpv display, I guess you arent planning on strapping it to your head ;P
AVR wrote 11/11/2015 at 01:52 point
currently mounting it onto the Turnigy radio I have but I do plan on making a laser cut plywood head mount system ala Oculus rift style. I've seen lots of people do that online lately so I figured why not. But first running it mounted to the controller.
Richard Hogben wrote 11/12/2015 at 16:30 point
Nice, I havent made the jump to fpv yet, but I've been looking at those head mounted kits from hobbyking.
