all hand soldered
A project log for Ignore this ESP8266 board
I stole from every one. The huzza from Adafruit. Matts breakout board. Al1s board from here. NodeMCUs DevKit.
davedarkodavedarko 11/07/2015 at 20:244 Comments
danjovic wrote 11/07/2015 at 22:51 point
Whoa! Lotsa work! Amazing! Did you used hot air or soldering iron for the mini usb connector? I have just soldered one here using soldering iron and removing the excess of solder with threaded wire.
davedarko wrote 11/08/2015 at 08:43 point
I figured I had to do that at one point and I was in the mood yesterday. It's all soldering iron and luck. The micro usb was in fact the toughest, since I have no solder whick around and stripped wire didn't work much. Four of them where dumb luck done after soldering :)
Craig Hissett wrote 11/07/2015 at 22:49 point
Great work mate - they look tremendous!
davedarko wrote 11/08/2015 at 08:44 point
