Draft for new FabScanPi enclosure
A project log for FabScan Pi - 3D Laser Scanner
FabScan PI is a Stand-Alone Web-Enabled Raspberry Pi based Open-Source 3D Laser Scanner
mario-lukasMario Lukas 03/07/2016 at 13:193 Comments
We are working on a new FabScanPi enclosure. It is discussed at the FabScan google group.
Mario Lukas wrote 09/05/2016 at 18:10 point
Furthermore there is a drawing of the needed dimensions in this section: http://mariolukas.github.io/FabScanPi-Server/software/#config-file-values
Mario Lukas wrote 09/05/2016 at 18:09 point
You can find the laser cut files in different formats here: https://github.com/mariolukas/FabScan-Case/tree/master/current
WelshFred wrote 09/05/2016 at 15:08 point
where can I get the dimensions from to make the box myself?
