FabScanPi Workshop at Make Munich!
A project log for FabScan Pi - 3D Laser Scanner
FabScan PI is a Stand-Alone Web-Enabled Raspberry Pi based Open-Source 3D Laser Scanner
mario-lukasMario Lukas 05/02/2017 at 18:400 Comments
We will offer another FabScanPi Workshop at Make Munich this weekend. You can sign in now! We are limited to 5 persons. At the and you will take home a DIY Open Source 3D Laser Scanner. Sign in now!
http://make-munich.de/Veranstaltung/fabscan-pi-build-raspberry/?instance_id=224
