Relay nodes
A project log for Home security
Home security project based on atmega and ardunio. MQTT gateway for data gathering.
vysocan76vysocan76 02/10/2017 at 15:010 Comments
Lately I started prepare mains powered relay board. It will sports 100-240VAC switching power supply delivering 3W at 5V. Then two 10A relays, rest will be as usual ATMega328P with RFM69 receiver. PCB design is almost ready and as soon as I get all parts I send it for fabrication. Size will increase to 56*58mm to accommodate all new components. There will be possibility to have onboard thermometer and switching power supply monitor to detect overloading.
Link to blog.
