HellZXcreiber
HellZXcreiber for ZX Spectrum
On the late 20's and Rudolf Hell invented the HellSchreiber, an ingenious fac simili teletext printer system, that was extensively used during WWII and later until the 60's. The HellSchreiber transmitter consists of a typewriter machine connected to a spinning drum with contacts that creates a digital (binary) modulation of the 'pixels' of the typed character. The receiver consists of a spinder wheel activated by a solenoid that creates marks on a reel of paper that continously run. It's simple, it's brilliant, but with advance of telecommunications the Hellschreiber was abandoned. In the early 90's the home computers got more advanced which allowed the Radio Amateurs to rediscover this method of communication by performing the encoding and decoding of the signals in software. Indeed, several variants were created and up till today it has several users. Even in the 80's the computers could have done that, with a proper software. That's what this project is about.
The audio signal is input to the EAR socket of ZX spectrum.
Key controls:
  • '9' changes reception speed preset (105, 122.5 and 245 baud)
  • '5' tune down (decrease) reception speed
  • '8' tune up (increase) reception speed
  • '0' when pressed plots black pixels to check present rendering position
  • 1 × Text Editor with Z80 assembly Highlight The choosen editor was "Context"
  • 1 × Z80 Assembler It was used PASMO, that can generate .tap files to be loaded on an emulator
  • 1 × ZX Spectrum Emulator Can be either Fuse, RealSpec, Eighty One, or Spectaculator. Fuse was used due to its timing accuracy
  • First working version
    danjovic04/13/2014 at 19:11 0 comments
    Finally I could get my hands again on a real ZX spectrum (TK90X). The first tests showed that a single sample for each bit produced bad results (video).
    A new sample routine was added within the delay loop for each bit. If there is signal a counter is incremented. At the end, if at least 1/4th of the samples were active, then a symbol (bit 1) is recognized and plotted as a black pixel. Otherwise it plots a white pixel .
    This sampling routine was tested with the sound sample found in the Wikipedia article about Hellschreiber (video)  as well as with some text generated by fldigi (video) and behave very well. It makes possible to use the volume control to change the 'intensity' of the black ink, which may be very useful when testing with live reception signals or recorded from live radio. This was tested using the sample in WB8NUT website.
    Source code in .asm as well as .tap image available.
  • Early Release
    danjovic03/23/2014 at 18:19 0 comments
    This is an Early Release for the project. The Decoder is working on the emulator and it's ready to be tested on a real machine. It can toggle between 3 basic speeds and allow the tweaking of the speed. The input shall be performed by key 0 or "RIGHT" on a Kempston joystick
View all 2 project logs
Alex wrote 09/07/2018 at 06:51 point
Nice! How about hell transmitter?
Noone wrote 08/07/2014 at 08:24 point
In the 1970s and 80s, Hellschreiber software was made for Apple ][, MS-DOS, Commodore 64/128, Olivetti M10, Tandy 100, Acorn, Z80, etc. See www.hellschreiber.com
