One of the most important procedures that make surgery possible is sterilizing the medical apparatuss. Sterilization has usually been carried out via chemicals and/or dry heat . Both of these sterilization procedures have many disadvantages. Chemical sterilization involves noxious chemicals that are used as sterilizing agents. These are usually chlorine, bromine and other (more dangerous) substances. Dry heat sterilization consumes a lot of energy and can degrade specific pieces of medical equipment. Not all medical hardware can be sterilized by these 2 methods.
My sollution to this problem is the following: PLASMA STERILIZATION.
Plasma sterilization has never been used. It consists of inserting the items to be sterilized into a vacuum chamber. A magnetic field (RF) creates a plasma inside of the cavity. The plasma acts as a miniature sandblaster and also destroys organic matter, many times more efficiently and much quicker.
Components
1×
Vacuum pump
Something to get rid of most of the air
1×
Bell jar
Where plasma is made
1×
Coil
Induces the RF field
1×
RF generator
Couple watts (or more) at many megahertz(15-20)
1×
Matching network
To elliminate reflection losses
Hi guys just a little update, we will post some new things about the theory behind our little project maybe some calculations or something like that. Stay tuned.
Hi guys we are here with an update, the components are ready. Thankfully they are performing properly and we will assemble our device and will put it to the tests.
HI guys we are here with an update. Unfortunately one of our components didn't performed as expected and so we needed to order a new one. Hopefully it will arrive tomorrow and we will then proceed further with the plan. Stay tuned for more updates ;
Hi guys, we are excited to let you know that all our components needed for our project have finally arrived and we need to run some tests on them to see if they are really working at the right parameters and hopefully, if the tests run smoothly, we will assemble the device. Stay tuned for more updates.
