UP1 Dev kits launched
10/24/2015 at 06:02 • 0 commentsLaunching the UP1 Dev kits
It has long been under development, now you get your very own. At UpDroid, we are really excited to launch the Dev kits for UP1 robot.Be a part of robotics history with the very first hassle free robotics platform for everyone.
No need to get frustrated by the mess of wires or the string of build errors while working on your robot, here is the perfect solution for you. Assemble the UP1 and watch as it follows your instructions like magic!!
Use UpCom (our browser based IDE) and own ROS (Robot Operating System) like a boss.Visit our website https://updroid.com/ to learn more about the UP1. We have a limited quantity of these kits so pre-order now and have the new UP1 Dev kit waiting at your door before Christmas this year.
Happy programming,
The UpDroid Team -
Depth map sample
09/09/2015 at 18:48 • 0 comments -
Tuning depth map
09/09/2015 at 16:02 • 0 commentsPlaying with the distance between cameras to tune the depth map
MoveIt! implemented on UpDroid
08/20/2015 at 23:15 • 0 commentsWe finally transitioned all our code base and builds to Intel's Edison and successfully implemented moveit! for both single and double arms. Here is a short video of the demo.
Anti-collision arm path planning
08/03/2015 at 23:33 • 0 commentsWe tested out the real time path planning for the arm and here is the result.
IO module customization
07/31/2015 at 22:47 • 0 comments
This concept is to target 8 years-old kids and up to engage
with robotics, as a friendly approach we came up with different iterations to
customize the IO module with facial features, in the ideation process, many
ideas were taking into account, after getting feedbacks from a customer, we
decide to go for the eyebrow and smile idea since it will give confidence and
friendliness to the kids to start interacting with the robot, also the black
color offers a neutral and elegant emotion with the minimum of part change
required. -
UpCom Basics
07/18/2015 at 02:36 • 0 commentsNate here describes a couple of basic features of UpCom being used on a ROS robot.
UpCom 0.5.0 release
07/15/2015 at 22:40 • 0 commentsWe have just released the latest version of UpCom v0.5.0. This release overhauls the aesthetic design and under the hood features of commander. Now its easier to access the files and folder as well as use the GUI tools to execute the launch files. You can directly install the latest version on your ubuntu systems from here.
Kartik Tiwari
required.
