I've spent the last week or so taking a break since I found out that the project didn't make it past the first round of the Hackaday prize. It would have been fun to keep going, but it means a lot less stress :)
I finally got around to trying out the SMD removal kit that I got from Adafruit, and it worked awesome! It hardly took any time at all to get the CS4272 off the board and replace it with a new one:
The two ICs in the bottom of the picture are the two that I removed to try to fix the board after it didn't work. The smaller IC is the I2C isolator that I mangled with a diagonal cutters to separate the pins so that I could remove them one at a time. The other is the codec that I removed using the chipquik kit and it was way easier (and I didn't almost destroy one of the pads).
It's a little annoying to replace $12 worth of components because I forgot to load 4 pull up resistors worth a total of around 0.03, but that's what happens when you rush, I guess.
On another note, now that the Hackaday contest is over, I can focus on getting the board production ready, and getting a kickstarter going. Here are a couple of goals for the next month or so:
- Finish integration into the Teensy Audio Library
- Should go a lot faster now that I have a working prototype
- Test out the Raspberry Pi adapter boards that I sent out to OSHPark a few weeks back
- They should be arriving soon
- Find a more user friendly software setup for the Raspberry Pi
- Instructions for auto-resampling, resampling quality settings, etc
- Make some changes to the board for better usability
- Use solderable jumper pads for configuration instead of 0-ohm jumpers
- Lengthen pads for power supply ICs
- Change hole sizes for header pins and make sure that the pins are all on a 0.1" grid
Hopefully I should be able to get everything done soon and should have a kickstarter going in a month or two!
