Change of plans
A project log for Wireless Flux Capacitor
A networked flux capacitor status indicator.
beamsjrBeamsjr 04/17/2014 at 12:590 Comments
I have decided to make a change from wired ethernet to wireless after learning about the new CC3000 module from Ti.  I should have the module in in the next few days, so I will get it on a breadboard and start testing out some code to get it working. I have redesigned the control module to add the breakout headers for the wifi board and added pinouts for the digital and analog pins so I can easily breadboard the module and reuse it if i choose. I also added rx , tx and power leds to the board. Below you will find the layout I ended up with.
