ESP8266 Web Server (Without Arduino)
Back to overview
How to build a web server with a $4 WiFi Module called ESP8266 without using an Arduino
Purest of Grainest wrote 01/11/2017 at 03:41 point
I built this example on a Witty Wifi Cloud dev boards and changed the code to match the on board RGB LED. Works great. Thanks for your example, it was great!
teaMJPx wrote 06/11/2015 at 04:03 point
Thank you for this, I've struggled a few days and this works well as a starting point. Thanks!
