Hackaday.io Hackaday.io
Sign up Log in
Baofeng Arduino Backpack
An Arduino Nano mount that fits on the battery of a Baofeng UV-5R or BF-F8.
timTim
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
46.1k views
8 comments
1.4k followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 8
View Gallery
46.1k
8
1.4k
154
Team (1)
  • timTim
Join this project's team
  • Files on Thingiverse
  • Morse Code Sketch supporting GPS
hardware
ongoing project
baofeng uv5r bff8 Morse code aprs arduino ham radio
Related lists
Atmel Arduino Projects
Arduino is an open source hardware platform for making interactive objects that can sense and control the physical world.
Amateur Radio
Ham radio projects that spin our tuners
Morse Code Projects
dit dit dit dah dah dah dit dit dit
projects
stuff
BAOFENG
Relação de projetos voltados para os rádios da fabricante chinesa BAOFENG.
Browse related lists
This project was created on 05/24/2015 and last updated a year ago.
Description
I wanted to use my BF-F8 for a fox hunt, so I needed to attach an Arduino and power it. The backpack slides onto the grooves in the back of the battery meant to align the battery with the charger. There are 3 contacts on the back of the battery used for charging. They expose the full battery voltage (2 cell lithium) so I'm using that to power the Arduino. As a future improvement, I'm mounting a GPS (ublox neo 6m) it the backpack as well. Initially the fox is going to be able to it's callsign and GPS position out with morse code. Later, I want my radio to transmit APRS info. I've always wanted to have APRS in my car.
Components
  • 1 × Arduino Nano
  • 1 × 3D printed parts
  • 1 × Stereo 1/8" plug
  • 2 × 1k resistors
  • 1 × some wire
View all 6 components
Project Logs
Collapse
  • Initial Code
    Tim • 05/28/2015 at 03:35 • 0 comments
    I'll be filling out more details including build instructions soon. For now, I just added a GitHub link for the initial code. https://github.com/timogiles/ArduFoxGPS. Stay tuned for more details!
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
jay wrote 05/18/2023 at 00:18 • point
Anyway to program this to do APRS?
mitchnmccarthy wrote 02/02/2022 at 18:30 • point
This is a really cool project!  Did the code and wiring diagram ever get finished or posted?
brembot wrote 04/09/2018 at 07:17 • point
Hi, do you have the circuit diagram? Thanks
Kenneth Domingue wrote 02/06/2017 at 19:45 • point
Hey Tim,
Have you been able to get this working? How well does the ublox neo 6m work? Any other updates on this project?
Thanks, Ken
Justin Herman wrote 04/19/2016 at 17:54 • point
Do you have a design file for the backpack?
Richard Hogben wrote 04/19/2016 at 18:50 • point
There is the thingiverse link http://www.thingiverse.com/thing:845061
ZaidPirwani wrote 09/02/2015 at 10:06 • point
sorry, but I am not getting why have you put an Arduino on it, can you please explain..
recently got these Baofeng radios, was looking here at Hackaday what others are doing with them... other than using as they are intended to be.
Tim wrote 09/02/2015 at 11:54 • point
Good question.  I'm connecting the arduino to the the radio so that it can cause the radio to transmit and send audio.  And by audio I mean square waves.  I have linked to my code that will cause the Arduino to transmit morse code messages which is useful for fox hunting.  I need to come back and put more information here because it works very well.
Save Lithium-Ion battery!
Project Owner Contributor
Battery ( Li-Ion ) care
daveDave
This solar powering unit is a time switching battery powered solar charged circuit, used to power an Arduino Uno and some peripherals.
Solar powering unit for Arduino
patel-darshilPatel Darshil
Small battery for your ESP8266 devices.
Coin Battery Shield for D1 Mini
dehipudeʃhipu
2021 Hackaday Prize
Battery capacity measurement using Arduino [Lithium-NiMH-NiCd].
Measuring the Battery Capacity [Lithium-NiMH-NiCd]
hesammoshirihesam.moshiri
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Baofeng Arduino Backpack", please tell us the reason.
Send message
Remove Member
