14.06.2015 Wifi Enabled Data logging and display chair
A project log for Sit.Up
Sitting for long periods has become more common in today’s life causing serious health issues. Sit.Up!
electrobobelectrobob 06/13/2015 at 23:170 Comments
After the first successful tests using capacitive sensors I implemented the thing in the chair. Here are the modules as size comparison. The new module can sit on top of 2 AA batteries and will not require more than 2 wires leaving from it.
DSC_4728
Due to the nature of the capacitive sensor, having an ISP/serial cable connected to the PC influences the measurement. In order to develop the software I connected an LCD and in the end I thought it should stay on the chair for a while.
There are 2 electrodes made of aluminium tape: the one towards the back is the ground and the one towards the front is the sense. The capacitance is measured between the two and when a person sits, it increases. I could not find any normal sitting position on the chair which does no detect the person. Here is the whole thing assembled.
DSC_4756
And of course, some data logging on the LCD:
DSC_4747
