Schematic v1.0
A project log for DrDAC USB Audio DAC
An escape from the tyranny of low-quality soundcards
drewrisingerdrewrisinger • 05/28/2015 at 05:44•0 Comments
This is the schematic that corresponds to version 1.0 of my design. It's divided into 4 sections: the USB section (which takes USB signals in, and outputs I2S Data), the I2S DAC (which outputs a balanced audio signal), the output opamp power supply section, and the opamp circuit itself, which provides the output.
USB Section
I2S DAC
Opamp Power Supply
Opamp Audio Output
