It is convenient to have a simple file system for use on the SPI EEPROM or RAM, to allow a number of wave tables, WAV files, or other files to be assembled on a host and then written to the EEPROM as one file.
The NASA developed EEFS is a good solution for this need, but it was developed with 32 bit machines in mind. The AVR ATmega uses 16 bit pointers, and so there needed to be some changes.
