Making a boot logo
A project log for Onboard Stellaris car computer
Audi A4 onboard computer based on the Stellaris launchpad board.
rui-rexRui Rex 06/15/2015 at 14:160 Comments
When I turn the key on I want it to boot with the Audi logo :) This can be changed for whatever I want.
I searched for a picture online, then edited it to remove unnecessary blank space (I'm not using any compression on the images to improve speed), scale it to fit on the 320x240 display and then convert it to 16bit RGB565 format.
This is the format used by the display and it's easier to have the picture saved already in the correct format.
First I thought on using an SD-card to save the pictures, but with the vibration of the car I could have to solder some wires to avoid bad connections. But I managed to cut the image a bit and it fits on the micro's flash without occupying much space. It's also faster as I don't need to read it from the SD card and then write it to the display.
