OBD2 support
A project log for Onboard Stellaris car computer
Audi A4 onboard computer based on the Stellaris launchpad board.
rui-rexRui Rex 11/17/2015 at 17:150 Comments
My initial thoughts included an interface with the car's OBD2 interface but I though it would be a bit hard to get the protocol right.
But this changed a bit as I found that some people were already doing this on arduinos (OBDuino, there's a lot of info on this) and the opengauge project (https://github.com/magister54/opengauge) so maybe there's hope on this chapter :)
I'll check if I can convert this to pure C code and use it on this module.
For the electrical part I was thinking of using a cheap OBD2 bluetooth dongle and removing the bluetooth module so I could interface the UART pins directly from the Stellaris.
My Audi A4 doesn't have a CAN interface but instead K-LINE (ISO 9141-2 protocol) at about 10kbps so the update rate isn't so good. It will have to do...
More on this latter...
