ARDUINO LOGIC ANALYZER
A standalone 3Mbps Arduino based logic analyzer, inspired by the "quick grab" and NOP timing techniques of Bruce Gillham, but very different
One of those projects you knock up to get you out of a corner. Takes 1500 readings after trigger, with a 320 sample display scrolled display. Also offers a grab mode using NOPs to give reasonably accurate 1, 2, 4, 8, 16 or 32 uS inter read displays. A cursor can slid across the display, set by a pot value, and "uS from trigger" is displayed, giving the opportunity to do some reasonably accurate measurements. Commercial quality pots give excessive jitter, and I suggest a 10 turn pot be used for setting the cursor. Cursor implementation is rather crude, as it is redrawn at every screen draw. It is done this way because of lack of a "get pixel" in the graphics lib, which would enable you to write functions to move a cursor across an existing plot without disturbing points already plotted. Code and notes at excelworks.info
vincenzo wrote 11/25/2016 at 10:06 point
K.C. Lee wrote 05/29/2015 at 00:16 point
