Flight Controller
AfroFlight Naze32 Acro
Motors
DYS 1806-2300
ESCs
DYS - BLHeli 20A Opto ESC
Receiver
OrangeRx R615X w/CPPM
FPV Camera
Aomway Mini 600TVL CMOS Camera
Video Transmitter
Aomway Micro 200MW 32ch 5.8GHz
Antenna
ImmersionRC 5.8GHz Circular Polarized SpiroNet Antenna V2 (RHCP SMA)
Battery Eliminator Circuit
Turnigy Plush 6A ESC (for 5V)
LiPo Alarm
HobbyKing™ Lipoly Low Voltage Alarm
Props
Gemfan 5030
Dimensions
270mm motor to motor
Layout
Perfect X layout
Weight without battery
354 gram without battery
Weight with 1300 mAh, 3s battery
489 gram
3D Printer
Makerbot Replicator
Filament
PLA 1.75
3D Print time
~7 hours total
Modeling software
Autodesk Fusion 360
Files available at
https://grabcad.com/library/376097
