Hackaday.io Hackaday.io
Sign up Log in
Theo Jansen RC toy
This toy is all made of clear 6 mm acrylic that i cat with my home made CNC router.
estEst
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
7 comments
427 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 7
View Gallery
1.6k
7
427
10
Team (1)
  • estEst
Join this project's team
  • video
  • I made a new version, video here!
hardware
completed project
Related lists
Favorites
List of favorite projects
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 05/31/2015 and last updated 9 years ago.
Description
All the mechanism and the gears between the DC motors and the legs are made out of acrylic that i cut with my home made CNC router. The gears and the legs turn on M5 screws with a bit of grease. I was planning to add lights on the legs, on the body and also an encoder to control the lights according to the position of the legs but i got lazy and i did not complete this part. The mouth is driven by two geared stepper motors, one was enough but I used two. I used 433 Mhz Rc/Tx modules controlled by a PIC micro controller for the transmission of the signal with a communication protocol derived from IR TV remote. The two DC motors that move the legs are controlled proportionally by means of a joystick.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Mike wrote 10/27/2015 at 19:07 • point
I would love the dxf.
Est wrote 10/28/2015 at 00:20 • point
i do not know how to use github. I can send to you by email
Stan wrote 07/01/2015 at 00:11 • point
Lovely piece of work - very Heath Robinson. If you publish the plans would like to build one with esp8266 as the 'Brains'.
Est wrote 07/01/2015 at 11:22 • point
do you want the drawing? i can send to you a dxf  but it will be a bit messy. I am lazy to tide up.
Est wrote 10/28/2015 at 00:21 • point
I do not know how to use github. I can send to you by email
Gravis wrote 06/30/2015 at 11:44 • point
you didn't shoot the video right, dummy!
Est wrote 07/01/2015 at 00:04 • point
ahahah, I got it. My excuses
I used the Primus X flight controller board to manoeuvre an extremely agile hover-craft frame I designed.
Project Owner Contributor
Hover-Craft
siddharthcsiddharth.c
An inexpensive robot arm retrofitted with H-bridge motor controllers and closed loop control
Reactron material transporter: OWI-535 Robotic Arm
kenji-larsenKenji Larsen
Being an engineer myself I could not resist adding remote control to this manually expandable lamp I saw at IKEA
Remote Controlled IKEA Death-Star Lamp
audriusAudrius
"Whosoever balances this hammer, if they be worthy, shall possess the power of Thor..."
Enchanted Thor Hammer
vipin-mVipin M
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Theo Jansen RC toy", please tell us the reason.
Send message
Remove Member
